45xp for cutting perforated materials?
exapprentice
Post by exapprentice »
Hi
Just a quick question!
Can you cut perforated materials or meshes with the new 45 xp?
I know the older 45 had a selector switch on the front panel for doing this
Anybody cut mesh or perforated materials with the new 45 xpand any chance you could post your settings?
Best Regards to all
Exapprentice :D
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting :(
Re: 45xp for cutting perforated materials?
That info should be in the manual, look at the description of the front panel.
exapprentice
Hi Tom
Good shout apart from all the 45XP manual says about cutting expanded metal is:
Cutting expanded metal
To cut expanded metal, use the consumables for shielded cutting that come with the system. The
system does not require a dedicated mode for cutting expanded metal.
Expanded metal has a slotted or mesh pattern. Cutting expanded metal
wears out consumables more quickly because it requires a continuous
pilot arc. A pilot arc occurs when the torch is fired but the plasma arc is
not in contact with the work piece.
I cannot find any other reference to cutting expanded materials ideally would've of liked someone to come back with some cut setting for thickness of materials etc. :Sad
But thanks for the response
Best Regards to all
Exapprentice :D
(Pete)
Here is a video which might be helpful.
https://www.youtube.com/watch?v=bDtlEh5Ve2k
exapprentice
Hi David
Thank you I did see that video and also another video he made on the same job showing the complete cut of the mesh
What I am really looking for are settings to dial in and maybe the technique for touch off
Guess I will have to wing it 🙂
But thanks again for your reply
Best Regards to all
Exapprentice :D
(Pete)
I would suspect you would use the same settings that you would if the material was not perforated and just keep the THC off.
