I've been testing the Proma 150 trying to figure out the best cutting speeds / cuttings AMP's / Mach3 Anti-dive setting / Z-Axis Speed / Proma Voltage, D-T , Hysteresis... so much to figure out. Cutting 4mm steel. It all seems to work though!!
https://www.youtube.com/watch?v=SX-l0OILL30
I also updated my control box. I purchased another G540 to control the rotary axis and provide more inputs. I removed the 2 of 4 limit switches I had and set up soft limits. The soft limit switches are only active during the ref all home function. After this you can manually trip them and it has no effect on the mills movement. Perfect solution when EMI trips the limit switches.
Time to start working on the rotary pipe cutter next.
