Someone asked how to export DXF, JPG, and PLT files all at once in corel.
Here is a corel vba macro to do that, with 3 gif images describing how to use it
savex.zip
Step 1 describes where to put the macro file
Step 2 describes how to make it a toolbar button in corel
Step 3 describes how to edit the macro code file to choose which formats to export or not
All done in X3, other versions may look different but should work much the same. It should work in any version of corel back to 11 or whenever they added vba support.
It is very minimal, it just exports the current file without asking any questions or presenting any options.
It exports files with the same name and location as the current file only with different extensions, and overwrites any existing files with the same name.
It uses corel default export settings for each file type, so whatever settings were in effect the last time you exported to each format will apply.
Typically you'd always save your work in .CDR or .CMX files, and use this to export a standard set of other common formats needed for downstream processing.
Corel VBA Macro to Export Mutliple File Formats
1 post
• Page 1 of 1
1 post
• Page 1 of 1
Jump to
- Welcome Center & Meet Our Sponsors
- ↳ Introduce Yourself
- DXF Design & Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table & Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- ↳ Tracker CNC Website
- CAD-CAM & Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories & Tool Related Forums
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
