gcode to dxf
- superoverenginered
gcode to dxf
I was wondering if anyone on here knows of a simple yet effective gcode to dxf converter that I can download.? I have tons of code files and no way to backplot them. Any help would be greatly appreciated. Thank you..Billy
Why make one when you can make 2
5x10 Arclight Dynamics plasma table
powermax 65
Concrete Printer with dewalt router
Miller mig/tig
powermax 65
Miller mig/tig
Re: gcode to dxf
The copy of one cnc that i have been using is able to do the back plot.
hope this helps.
hope this helps.
Re: gcode to dxf
I found a program called KMB Trace on download.com it is supposed to do a gcode backplot and has an option to put it back out as .dxf. I haven't had time to play with it yet to see how/if it works as it is kinda old without updates... may be buggy...
http://download.cnet.com/KMB-Trace-2007 ... 26474.html
Ps. it is for windows... not sure if that's what you are using or not also what other software are you using as that may give you other options on how to convert
Re: gcode to dxf
thanks ppls...I will check it out when I get to work...thanks a ton!
powermax 65
Miller mig/tig
powermax 65
Miller mig/tig
