Do you leave the dryer running all the time or only when cutting? Do you relieve the pressure to the dryer each time you turn it off?
Question for HF refrigerator dryer users
Re: Question for HF refrigerator dryer users
I turn mine off when I'm not cutting and air is not running through it, but I don't bother to relieve the pressure.
I turn mine off and relieve the pressure. Only reason I relieve the pressure is so the auto drain will dump whatever water is trapped in there each day.
Same, turn it off nd relieve the pressure.OffRoadDevilDog wrote: Thu Jun 04, 2020 12:01 pm I turn mine off and relieve the pressure. Only reason I relieve the pressure is so the auto drain will dump whatever water is trapped in there each day.
Mine is a different brand (Speedaire purchased back in 2003). I turn it on when I turn the compressor on for the day, and power it down when I shut down the compressor. It usually purges the condensate the next time I power it up and turn on the air. It has a small drain tube out the bottom of the dryer.
