I built the following charge pump for my Mach3 controlled machine, it works well so I thought I would share it...
My Mach3 Charge Pump Design
- FabLab
Re: My Mach3 Charge Pump Design
Pardon my ignorance but I am curious as to what a charge pump is?
- FabLab
Mach3 will output a 12.5kHz signal when its running, with the use of a charge pump you can disable the electroics, motors, etc. on you machine until Mach3 is fully up and in control.
Because I am using a parallel port to control my machine if the PC is rebooted unwanted signals can be sent out of the parallel port causing unexpected machine movements
Its just a safety thing my circuit design uses a relay to cut the power to my power supply until Mach is running
Thanks for the explanation I have seen the Plasma torch fire when Mach is powered down, not good
Ahhhhh, I see now. Thanks for the explanation, I was curious.
DIY 2x2 table
- FabLab
Yeah, me too the 2nd time that happened to me I decided it was time to do the charge pump.acourtjester wrote: Mon May 25, 2020 5:55 pm Thanks for the explanation I have seen the Plasma torch fire when Mach is powered down, not good
- FabLab
No problem glad to help
