SELECT POST-PROCCESOR FOR STARIFIRE SF-2100 CNC
IM.OMVN
Post by IM.OMVN »
Hi,
Im noob on this.
I have a new cutting table with Starfire SF-2100 CNC and PowerMax 105 Plasma, comes with FastCAM Software but now Im looking for more versatile software like SheetCAM.
Im trying demo version of SheetCAM, however i cant found the correct post-processor for this CNC, can you please help me to make test.
I attach a DXF File and the correct G-Code generated for FastCAM for this file.
I really apreciate if you can help me.
Thanks.
Sincerely,
Oscar Vega
MANCUERNA 30 LBS.rar
(9.54 KiB) Downloaded 136 times
Dfabltd
Re: SELECT POST-PROCCESOR FOR STARIFIRE SF-2100 CNC
Post by Dfabltd »
send me your email I have script for this machine g92 is speed settings which starfire will not read and shuts down
Les Newell
Post by Les Newell »
I have attached a couple of posts that should work. Use the 'Baileigh Starfire' post first. If you have problems with arcs use the 'no arcs' version.
To install a post, copy the file to any convenient folder on your computer then run SheetCam and go to Options->machine->post processor. Click on the 'Import post' button. Using the box that appears, navigate to your post and open it. Go back to Options->machine->post processor and make sure your post is selected.
posts.zip
(1.92 KiB) Downloaded 298 times
posts.zip
Return to “SheetCam”
