I am having a sudden problem with post 27E.
As of this week when I run the post processor, it no longer turns on auto THC, or call a cut height. I can not figure out what has changed. The file will run, touchoff, go to pierce height and cut at that height only. Torch never drops to cut height, and thc never comes on.
Running Command CNC on a mini computer. Sheetcam version is 6.1.57
I would think it's a problem within sheetcam, but I am unsure of where to start looking.
I have attached a copy of good code
(Filename: crown wedge set 375 steel.tap)
(Post processor: CandCNCPlasmaLLCNC-rev27E.scpost)
(Date: 15/01/20)
G20 (Units: Inches)
F10.0
G90 G40
G64 P0.010 Q0.001 (tracking tolerances set to 0.01)
M68 E0 Q10
(Part: crown wedge face)
(Operation: Outside Offset, 0, T19: 65 amp 3/8 steel)
M68 E0 Q89 (Auto Preset is not active )
G4 P.1
(Preset Volts: 126)
(Preset AMPS: 65)
(Air Pressure Preset: 75)
(Soft pierce is off )
(Suggested Tip Size: 65 )
(DTHC Delay: 2 sec )
(Min Cut Length for DTHC ON : 1 units )
M68 E0 Q3126 (Preset Volts set to 126 Volts)
G4 P.1
M68 E0 Q465 (Preset Amps set to 65 Amps)
G4 P.1
M68 E0 Q875 (Air pressure set to 75 PSI)
G4 P.1
M68 E0 Q520 (DTHC Delay set to 2 Seconds)
G4 P.1
M68 E0 Q10 (DTHC is OFF)
G4 P.1
(MSG, The PAUSE after this message is to allow the Operator to check the DTHC settings to confirn they are loaded from the G-Code and are correct. If you need to change anything do it before you hit the RESUME button to continue)
M1
G0 Z0.787
G0 X26.189 Y0.151
G0
G0 Z0.39
o<touchoff> call (external Touch off from Commandcnc)
G1 Z0.150 F150.0 (Z plunge move to cut height)
M68 E0 Q20 (Auto DTHC is ON)
G4 P.1
M3 S100
G4 P0.7
G1 X26.189 Y0.151 Z0.060
G3 X26.029 Y0.311 I-0.160 J0.000 F45.0
G1 X1.029
G2 X0.991 Y0.349 I0.000 J0.038
G1 Y34.099
G2 X1.029 Y34.137 I0.038 J0.000
G1 X26.029
G2 X26.067 Y34.099 I0.000 J-0.038
G1 Y0.914
S10 (THC OFF)
Y0.349
(Part: crown wedge back)
G4 P.1
G0 X26.068 Y0.350 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X26.067 Y0.349 Z0.787
G0 X44.236 Y0.151
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X44.236 Y0.151 Z0.060
G3 X44.076 Y0.311 I-0.160 J0.000 F45.0
G1 X27.076
G2 X27.038 Y0.349 I0.000 J0.038
G1 Y34.099
G2 X27.076 Y34.137 I0.038 J0.000
G1 X44.076
G2 X44.114 Y34.099 I0.000 J-0.038
G1 Y0.914
S10 (THC OFF)
Y0.349
(Part: crown wedge sides Duplicate 5)
G4 P.1
G0 X44.115 Y0.350 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X44.114 Y0.349 Z0.787
G0 X26.279 Y34.583
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X26.279 Y34.583 Z0.060
G3 X26.119 Y34.743 I-0.160 J0.000 F45.0
G1 X25.787
G2 X25.749 Y34.781 I0.000 J0.038
G1 Y51.781
G2 X25.813 Y51.809 I0.038 J0.000
G1 X44.133 Y34.798
G2 X44.107 Y34.732 I-0.026 J-0.028
G1 X26.684 Y34.743
S10 (THC OFF)
X26.119
(Part: crown wedge face Duplicate 1)
G4 P.1
G0 X26.120 Y34.744 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X26.119 Y34.743 Z0.787
G0 X25.401 Y34.403
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X25.401 Y34.403 Z0.060
G3 X25.241 Y34.563 I-0.160 J0.000 F45.0
G1 X0.241
G2 X0.203 Y34.601 I0.000 J0.038
G1 Y68.351
G2 X0.241 Y68.389 I0.038 J0.000
G1 X25.241
G2 X25.279 Y68.351 I0.000 J-0.038
G1 Y35.166
S10 (THC OFF)
Y34.601
(Part: crown wedge back Duplicate 1)
G4 P.1
G0 X25.280 Y34.602 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X25.279 Y34.601 Z0.787
G0 X47.582 Y47.789
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X47.582 Y47.789 Z0.060
G3 X47.422 Y47.949 I-0.160 J0.000 F45.0
G1 X30.422
G2 X30.384 Y47.987 I0.000 J0.038
G1 Y81.737
G2 X30.422 Y81.775 I0.038 J0.000
G1 X47.422
G2 X47.460 Y81.737 I0.000 J-0.038
G1 Y48.552
S10 (THC OFF)
Y47.987
(Part: crown wedge sides)
G4 P.1
G0 X47.461 Y47.988 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X47.460 Y47.987 Z0.787
G0 X13.312 Y81.136
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X13.312 Y81.136 Z0.060
G3 X13.538 Y81.128 I0.117 J0.109 F45.0
G1 X13.780 Y81.353
G2 X13.834 Y81.351 I0.026 J-0.028
G1 X25.428 Y68.918
G2 X25.400 Y68.854 I-0.028 J-0.026
G1 X0.400 Y68.802
G2 X0.374 Y68.868 I-0.000 J0.038
G1 X13.124 Y80.742
S10 (THC OFF)
X13.538 Y81.128
(Part: crown wedge sides Duplicate 1)
G4 P.1
G0 X13.539 Y81.129 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X13.538 Y81.128 Z0.787
G0 X12.571 Y81.447
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X12.571 Y81.447 Z0.060
G3 X12.563 Y81.221 I0.109 J-0.117 F45.0
G1 X12.789 Y80.978
G2 X12.787 Y80.924 I-0.028 J-0.026
G1 X0.354 Y69.331
G2 X0.290 Y69.358 I-0.026 J0.028
G1 X0.237 Y94.358
G2 X0.303 Y94.384 I0.038 J0.000
G1 X12.178 Y81.634
S10 (THC OFF)
X12.563 Y81.221
(Part: crown wedge sides Duplicate 2)
G4 P.1
G0 X12.564 Y81.222 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X12.563 Y81.221 Z0.787
G0 X12.835 Y82.664
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X12.835 Y82.664 Z0.060
G3 X12.843 Y82.890 I-0.109 J0.117 F45.0
G1 X12.618 Y83.132
G2 X12.619 Y83.186 I0.028 J0.026
G1 X25.052 Y94.780
G2 X25.116 Y94.752 I0.026 J-0.028
G1 X25.169 Y69.752
G2 X25.103 Y69.726 I-0.038 J-0.000
G1 X13.228 Y82.476
S10 (THC OFF)
X12.843 Y82.890
(Part: crown wedge sides Duplicate 3)
G4 P.1
G0 X12.844 Y82.891 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X12.843 Y82.890 Z0.787
G0 X12.292 Y83.172
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X12.292 Y83.172 Z0.060
G3 X12.065 Y83.180 I-0.117 J-0.109 F45.0
G1 X11.823 Y82.954
G2 X11.769 Y82.956 I-0.026 J0.028
G1 X0.175 Y95.389
G2 X0.203 Y95.453 I0.028 J0.026
G1 X25.203 Y95.505
G2 X25.229 Y95.439 I0.000 J-0.038
G1 X12.479 Y83.565
S10 (THC OFF)
X12.065 Y83.180
(Part: crown wedge sides Duplicate 4)
G4 P.1
G0 X12.066 Y83.181 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X12.065 Y83.180 Z0.787
G0 X25.467 Y94.858
G0
G0 Z0.39
G4 P.1
M3 S100
G4 P0.7
G1 X25.467 Y94.858 Z0.060
G3 X25.627 Y95.018 I0.000 J0.160 F45.0
G1 X25.628 Y95.349
G2 X25.666 Y95.387 I0.038 J-0.000
G1 X42.666
G2 X42.693 Y95.323 I0.000 J-0.038
G1 X25.682 Y77.003
G2 X25.616 Y77.029 I-0.028 J0.026
G1 X25.627 Y94.453
S10 (THC OFF)
Y95.018
G0 X25.628 Y95.019 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X25.627 Y95.018 Z0.787
(No Parking values detected. Moving back to zero, zero)
G0 X0.000 Y0.000
M68 E0 Q900
M68 E0 Q80 (Auto Preset is active )
G4 P.1
M68 E0 Q10 (DTHC is off)
G4 P.2
M5 M30
and the problem code
(Filename: roll off cable sheave plate.tap)
(Date: 06/04/20)
G20 (Units: Inches)
F10.0
G90 G40
M68 E0 Q10
(Part: roll off cable sheave plate)
(Operation: Inside Offset, holes, T19: 65 amp 3/8 steel)
G4 P.1
(Preset Volts: 126)
(Preset AMPS: 65)
G4 P.1
G4 P.1
G4 P.1
G4 P.1
G4 P.1
M1
G0 Z0.787
G0 X5.000 Y6.000
G0
G0 Z0.39
G1 Z0.150 F45.0
M3 S100
G4 P0.7
G3 X5.000 Y4.975 I0.000 J-0.512
X4.463 Y5.127 I0.000 J1.025
S10 (THC OFF) (Before end)
X5.000 Y4.975 I0.537 J0.873
G4 P.1
G0 X5.001 Y4.976 (Add tiny extension)
M5
o<endcut> call
G4 P0.5
G0 X10.115 Y-0.278 Z0.787
G0 Z0.39
G1 Z0.150 F45.0
M3 S100
G4 P0.7
G3 X9.875 Y-0.038 I-0.240 J0.000
G1 X0.125 Z0.060
G2 X-0.038 Y0.125 I0.000 J0.163
G1 Y10.375
G2 X0.125 Y10.538 I0.163 J0.000
G1 X9.875
G2 X10.038 Y10.375 I0.000 J-0.163
G1 Y0.434
Y0.125
G2 X9.875 Y-0.038 I-0.163 J-0.000
(End of job , noving to predefined Parking position)
G0 Z0.787
M68 E0 Q900
G4 P.1
G4 P.2
M5 M30
post problems
Re: post problems
I'm guessing it might have something to do with this.
First code has this
Second has this
It's probably trying to autoset the volts, but not sensing properly. Just a guess. No experience with commandcnc.
First code has this
Second has this
Re: post problems
djreiswig Thanks for the reply. Auto set is a THC control setting that can be turned on and off. I will have to look into that. I will have to look up the code because I am not sure what the auto preset refers to. This has me stumped because i have not made any changes within sheetcam,and this problem popped up all of a sudden. I am convinced at this point that i have inadvertently changed something and can't figure out what.
