0-30 - Torch consumables stuck - Advanced troubleshooting
Discussion on 0-30 fault codes
BTA Plasma
Post by BTA Plasma »
There are two 0-30 codes. There is a 0-30-0 which means (torch stuck open) or 0-30-1 (torch stuck closed).
Fault code 0-30-0 means the electrode and the nozzle not making electrical contact. Reasons may include:
Wrong consumables
Gas valve is open or leaking
Physical damage to the torch and/or consumables
A deformed swirl ring is stopping electrode movement
An over tightened retaining cap has damaged the swirl ring
Fault code 0-30-1 means the nozzle and electrode are stuck together and cannot create an arc. Possible causes may include:
Low gas pressure
Gas restrictions
Gas leaks caused by a damaged torch lead or regulator
Hose diameter impacting flow rate
External filters may be constricting the gas flow, verify all flow rates for components feeding the power supply
Gas restrictions
A deformed or damaged swirl ring is stopping electrode movement
Regulator needs to be replaced
To access which one you have the error must be up
If Matt is using this profile he is one of the OGs of Plasma. If not then a technician. We make the worlds fastest and largest CNC plasma tables up to 10x40. www.StarLabCNC.com :Like Check out our Facebook page where we update frequently. https://m.facebook.com/StarLabcnc/
Return to “0-30 Fault Code”
