Dxf issue
kennye
Dxf issue
Post by kennye »
I had a file made for a project I have . I think I have a problem with my setup some how because the file looks perfect and probably is .
the problem Im having is when I open it looks real good when I put it in sheet cam to resize and make a gcode to cut it still looks good but I noticed when I put it in mach 3 all the A"s are short only the A"s Has anyone else had this problem .I can change the font and use different and the A"s dont change
I really dont want to change fonts because they go with the rest of the letters on the piece .Does this make any sense on whats happening?
Re: Dxf issue
For some reason did you use capital letters except for the A's ??
