Upgraded to comandcnc ??
I have a table I built a few years ago with candcnc bladerunner controls. Uses mach3 system is windows xp. Still works and does about everything I need, but xp computers are getting hard to find.
so that leads to the question at hand have any of you upgraded to Toms Linux based system if so which one desktop or mini pc, how much of a learing curve was it.
most important are you glad you did the up grade, why ?
Mike
Mike
Re: Upgraded to comandcnc ??
Do you have the Ethercut? My pre commandcnc system is running Windows 7, but it is an Ethercut system.
If not and you are handy, you might be able to switch the parallel port to an ESS Smoothstepper. I'm not sure what the differences are, but the Smoothstepper acts like a parallel port and uses a Mach3 plug-in. Might be cheaper than a full upgrade.
Im thinking mine is NOT ethercut, not sure it is parallel port connected . As of now nothing is wrong it does what I need it for, but last year pc crashed and ii became clear finding older pc is getting harder to do.
I hate to fix whats not broken but preventive maintance is another thing.
My luck Linux will become obsolete a week after I upgrade
Mike
Mike
I have bought a few refurb PC from Overstocked.com they have Dell PC with operating systems on them and parallel ports form less then $120. Just look at the back side view and read the spects to be sure it has a parallel port.
https://www.overstock.com/Electronics/D ... 3&recidx=4
I'm very happy with the upgrade from Mach3 to CommandCNC (Linux). The weaknesses of the system are in the hardware, imo (PWM, hub, THC card), which are largely shared between both versions. The Linux system does everything Mach3 did, and many things it can't do. If you're going to stick with CandCNC, I'd go with the CommandCNC system.
That said, some folks seem to feel the parallel port version was the most "bulletproof" of the systems.
I bought a Dell refurb PC with my Linux upgrade. Didn't care for the mini. I also purchased a used/refurb Dell 755i box from eBay or NewEgg or something, as a backup. Loaded CommandCNC on it from the flash drives supplied by CandCNC with my Linux upgrade. In addition, I still have the Dell box I used for Mach, which should work for Linux as well (I believe they're the same box).
A friend of mine found a source for the mini-machines, which seem to match what CandCNC are using, at a significant discount. If you're interested in that, I'll look up the info.
Im a little leary of the mini for the fact if candcnc goes out of business for some reason I may be stuck with something I don't know anything about.
Tech things are not my strong suit, we all have different things we are good at, tech stuff aint mine,
I have never felt comfortable owning anything that cant be sourced from only one place.
Mike
Mike
This is the mini I was referencing earlier. I've not done the research myself, but I've been told this is essentially the same, if not exactly the same, as the mini sold directly by CandCNC.
https://www.amazon.com/QOTOM-BareboneMi ... gzW6dS3UNU
It sure looks be the same:
https://www.candcnc.net/store-home/commandcnc-mini-pc/
Keep in mind, when you buy from CandCNC it's (in theory) already to going to be pre-loaded, and working with the software you need.
There is nothing magic about the mini . Its an Intel based J1900 PC with an SSD, 2 - 4 Gigs of RAM and built in dual Ethernet ports. CommandCNC will also run on a lot of other PC platforms. The key is to have the correct Ubuntu and RTK (we supply it on a bootable memory stick) and the CommandCNC Installer (also on a separate memory stick) Not all PC's will run the Real Iime Kernel (RTK) for LINUXCNC We buy the mini from the same sources you can. I would worry more about them (in China) going out of business than us But you are wise to want to not single source everything.
As an ongoing Engineering project we continually test other computers and also updated Ubuntu and the RTK.
Tom I wasn't implying you were gonna bail out of the business any time soon. My thoughts on china if they stop shipping for a month we are all screwed.
I did not realize the mini was a readily available item, thought it was candcnc specific.
Thanks for the info
Thanks for the info
I've got Commandcnc on Linux using a refurb tower PC from CandCNC. Both have worked great going on 2yr of ownership with 1.5 of those years running 20hr a week (hobby & side-biz).
- WyoGreen
I've been running on CommandCNC since it first came out and like it a lot. It seems to run smoother and faster. I've had no problems with it at all (other than my own operator errors!)
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
