New to it all.
Buckmaster1967
New to it all.
Post by Buckmaster1967 »
So, Does Corel Draw Graphics Suite create G-Code? Or would I need another program fro that? Thanks
beefy
4.5 Star Member
4.5 Star Member
Re: New to it all.
Post by beefy »
Coreldraw is a vector graphics editing / creation program. It does not create gcode.
Typically that are 2 stages to creating gcode, although I think some software does incorporate both capabilities.
If you've ever heard the term CAD/CAM it's referring to the drawing part (the CAD e.g. Coreldraw, Autocad, etc) and gcode generation side (the CAM, in my case I use Sheetcam for plasma cutting). So for this explanation I'm using Sheetcam.
So I'll create the drawing in Coreldraw, export that drawing from Coreldraw as a DXF or SVG file, then import that DXF/SVG file into Sheetcam.
In Sheetcam there's a bunch of settings like feedrate, pierce height, cut height, leadin/leadout type & size, etc, etc.
Sheetcam also has a thing called a "Post Processor". There's a whole bunch of these to choose from in Sheetcam and you need to choose the one that's right for your cnc machine.
Once you've done all the settings in Sheetcam & selected the correct post processor, you then generate the gcode file for your machine.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
Buckmaster1967
Re: New to it all.
Keith,
Thank you very much for taking the time to explain this for me. Great site.
