The Combo Deal features Premier Grind 4.5" zirconia flap discs (German Made) and SELECT CUT 4.5” cut off wheels.
Priced at $35, this package includes:
25 – Premier Grind 4.5” x 7/8” Zirconia Flap Discs: Type 27 or Type 29 / 36, 40, 60, 80 or 120 Grit, and…
25 – SELECT CUT 4.5” Cut Off Wheels: Type 1 (flat)
Most of you know the drill…Use the COMMENTS section to let us know types and grits for the flap discs. If you leave this blank, we'll send T29 /10 - 40 Grit, 10 - 60 Grit and 5 - 80 Grit.
Seasons Greetings!
***Roark Supply is a leading provider of abrasives used by fabricators, as well as off-road and custom car enthusiasts.
