Drum sander conveyor Grizzly G0449
Learn and share abrasive & texturing finishing techniques, experiences, and product knowledge here.
szextreme
Post by szextreme »
OK guys need some help here Specifically if you or know someone that has basically a "Timesaver" type machine. Found a smoking deal about 6months ago on a dual drum 37" wide Grizzly G0449 drum sander. Spent a day cleaning out all the sawdust and making sure was completely mechanically sound before trying to throw some metal art on it. That time came and went real fast as the Conveyor belt isnt exactly up to par with the heat transfer of the metal (Yes I know its for wood) Does anyone know of a company that would make high heat conveyor belts? If the real "timesaver" machines can do metal I need to know what the material for their belt is or a place that makes such belts. Unfortunately I think a new conveyor belt custom made is going to double what we have into the machine!
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
-5000 Sq feet of toys......I mean Machinery!
TTMotorsports
Re: Drum sander conveyor Grizzly G0449
Post by TTMotorsports »
Set the metal art on a piece of plywood and run it through, adjust height accordingly.
szextreme
Post by szextreme »
Did try that, but one of two things happen...the piece sits on the drum and wood moves through or potential of airborn metal art due to not adhering to the wood. also tried sticky back sandpaper
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
szextreme
Post by szextreme »
Also the belt on the conveyor is a little bit dry rotted as you can pick off pieces of the belts nipples by hand
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
sphurley
Post by sphurley »
Its been a while but I think this is where I went.
https://2sand.com/feed-belt-for-grizzly-18-drum-sander
They made me a custom one for the dual drum sander you have. I sold it about a year ago.
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
whiskeymike
Post by whiskeymike »
Ever get this working well?
szextreme
Post by szextreme »
Haven't had a chance to really look into a belt for the conveyor. Also the drums need to be adjusted ever so slightly.
-Bulltear 5x12
-PM 85
-Miller Dynasty 400
cstroke
Post by cstroke »
If you still need help I can give you contact information of a guy I know that might be able to help you.
If you need this information PM me so I am guaranteed to see this.
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
Return to “Abrasive & Texturing”
