I just got around to hooking up a cutmaster 60i to my table. I used some of Candcnc hook up kit to complete the job. Mostly just needed the RAV-O2 voltage card to make it work with my system.. I had the Universal Plasma connection kit for years, so I used the digital current probe i had with it.. You can use pins #12-14 on the Cutmaster's J609 connection to get arc good that way also. pins #3-4 on the same connection are the start-stop trigger wires.. Then just the negative/positive for full arc voltage.. Also on the J609 connection, but i went straight to the leads on those. Mostly because I only wanted to use the start/stop pins on the J609 connection, because i don;;t have the correct female plug for the 18 pin setup. Just wired up two pins, and pushed the in the terminal. The Digital Current probe works excellent, so no downside for me.Had it on Esab's machines, and standard cutmaster's before this one.
There is no factory CNC connection kit out for the 60i yet, although the machine will support one. Has it in the manual with a 12 pin like real cnc setups..
By the way the machine is a beast even with the old tech torch. Seems to respond to the extra power in the machine. Makes my 45XP semm sort of weak.
https://www.candcnc.com/store-home/rav- ... ider-card/
https://www.candcnc.net/store-home/univ ... ction-kit/
