I use a guy down the road and his work is great.
He really gives you a good job and spends the time to sandblast, clean and turn your work into a great looking piece.
Although I was wanting to powder coat my own larger pieces.
I would like to be able to powder coat my own products that are practical when time allows.
I have powder coated my small pieces for several years now but I use the infra red propane burners I bought from Columbia coatings a few years back.
They are fine for small stuff but not for larger projects(even heat).
I took a look at the guys oven who powder coats my larger work.
He built his out of sheet metal panels (insulated).
It is basically a 8 X 10 room that is expandable by connecting more insulated panels to make it larger if needed.
I was wondering if anyone out there has built their own oven for larger projects like motorcycle frames, headache racks or even art work and stuff like that.
I found a few guys on ebay that build ovens that you assemble when they arrive.
Insulated panels, burners and thermostats that run off of propane.
Basically a kit oven about 6-8 feet tall and 4 x 4 wide.
At this point I have done enough powder coating to be able to successfully coat larger pieces.
I don't want to be the guy who takes business away from anyone but for me, being able to complete the whole project would be cost effective for sure.
I am not looking to build a huge expandable room like his but an oven just big enough to do what I need.
Does anyone have any tips that could get me pointed in the right direction?
Of course like most people I am not looking to spend a lot of money on a fancy set up just a functional oven that is capable of generating the correct temperatures for powder coating.
I did have access to a larger oven a few years ago and I was told to powder coat all I needed that weekend.
I will say this, it is amazing what can be done with a simple oven that holds the heat in.
It made the powder coating a breeze.
It made the infra red burners I have look like camping heaters for sure.
I figure with all the time we spend plasma cutting and building all this cool stuff, it would be great to be able to put a professional powder coated finish on them.
Sprayed on paint is fine for some stuff but you just cant beat the durability of powder coating for projects that will be used outdoors a lot.
If anyone has a good way to build a simple oven about 8 foot high and 5 X 5 square, that would be great.
Thanks everybody.
