CUrve text with ellipse
18 wide 10 high ellipse I cant seem to get the text to curve feature to work. I have tried just about everything!!!!!PLease Help need job done for FATHERS DAY
- Gamelord
- 4.5 Star Member
Re: CUrve text with ellipse
Probably could help you but might need a little more info. Is that in feet or inches or centimeters etc... Also, what is the text? Is it above the line, below the line or through the middle of the line? Also, what font and how big is the font? If you want help doing it yourself, what program are you using and what format do you want it in?
Once you know how to do it, it is pretty simple. It's just hard figuring it out the first time.
Torchmate CAD
Torchmate CAD
Thanks Gamelord for your response. I have figured it out I used the offset line it worked pretty good. Thanks Again!!!!
