1932 ford
wanda
1932 ford
Post by wanda »
Hey does anyone have a 32 ford truck? or the shriners symbol with the sword and the face?
thanks
Wanda
eggauto
Re: 1932 ford
Post by eggauto »
All I have is this one hope it will help.
azfabshop
Re: 1932 ford
Post by azfabshop »
This one took me a while to make but haven't tried to cut it yet. If u do I'd like to see it!
Patrick Waite
Re: 1932 ford
Post by Patrick Waite »
Very nice
Patrick
Patrick
azfabshop
Re: 1932 ford
Post by azfabshop »
Thanks, Im not sure if it needs work to be cuttable. My eyes started to cross following all the lines!
GeorgeNewman
Re: 1932 ford
Post by GeorgeNewman »
I imported it into Plasmacam, did a color change (white background, white grid & black closed paths) a screen print, and paste to Microshaft Draw. Then did a black fill. It isn't cutable as is.
George
azfabshop
Re: 1932 ford
Post by azfabshop »
If anyone does the touchups to make it cuttable please post it Thanks!
wrenchhead
Re: 1932 ford
Post by wrenchhead »
Im still learning but i took a shot at the shriners symbol. I have not cut it so it may need a little touch up.
38 Special
Re: 1932 ford
Post by 38 Special »
Shriners pic:
MQUICK
Re: 1932 ford
Post by MQUICK »
Both files can be cut but ver 2 has more support for cut out areas. I hope this helps.
azfabshop
Re: 1932 ford
Post by azfabshop »
Thanks !!Now when its not 112 degrees outside I may have to try to cut that one! I just set up shop in a pole barn that gained me a lot of space but I only have the little portable swamp cooler still and it only cuts it if u stand in front of it. Makes welding jobs tough too!
