Skull mount/hanger
jasprive
Skull mount/hanger
Post by jasprive »
Does anyone by chance have a skull mount/hanger file they can post, have a buddy wanting me to do a European skull mount for just wanted some ideas :) Thanks ahead of time really appreciated.
jasprive
Re: Skull mount/hanger
Post by jasprive »
I am working on 2 different ones now guess I will upload and share them when I am done to help others out.
sbest1
Post by sbest1 »
I have this file but haven't cut it so check it out well. Not sure about assembling. Might help get you started.
Mount-Final.zip
steel 35
Post by steel 35 »
Sweet File; The boot shaped toe & heal points drop in to 2, 1/4" x 1/2"long ? pieces of pipe welded to the right wall mount. drop the boot in and bolt the last piece to it. Very cool design and adjustable @ 1/2 hole's. I will be making lots of these. Thanks
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
jasprive
Post by jasprive »
Thanks :) yeah that is a good idea thanks for sharing really appreciate it
zoeconner
Post by zoeconner »
Anyone have a picture of this put together?
steel 35
Post by steel 35 »
zoeconner wrote:Anyone have a picture of this put together?
Here is my test cut, I need to fix peck's, and the pipe spacing's. :x
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
zoeconner
Post by zoeconner »
Any reason for it to pivot? Why not just weld it together?
tnbndr
Post by tnbndr »
Gives the option of better positioning after the mount is hung. Once welded you are locked in.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
Rockenjvdesign
Post by Rockenjvdesign »
Is this for a deer or elk?
Rocken JV Design We do it all
Plasma cam DHC2
hypertherm powermax 45
Custom furniture
Home décor
donn92
Post by donn92 »
i just built 6 of these trying to upload pics and it says too large can anyone help they fit the small skull i have perfect and the large one as well
Rockenjvdesign
Need to go in and crop the pics to a smaller size
Plasma cam DHC2
Custom furniture
Home décor
steel 35
Post by steel 35 »
Rockenjvdesign wrote:Is this for a deer or elk?
No Elk
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Rockenjvdesign
Anyone make one for elk?
Plasma cam DHC2
Custom furniture
Home décor
kbenz
Post by kbenz »
how does the skull mount to it? I'm having visualization issues here...lol
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Bobcat320
Post by Bobcat320 »
I will play with it, can probably just scale it up and would work fine for an elk.
Pretty neat idea!
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
DezertBlingMoto
Post by DezertBlingMoto »
can someone post the dxf I cant open it either. thanks in advance
plasmapros
Post by plasmapros »
DezertBlingMoto wrote:can someone post the dxf I cant open it either. thanks in advance
Here's the dxf dbling
Mount-Final.dxf
Highvoltage
Post by Highvoltage »
This is my version. Can make them any animal you want as a mounting plate.
Highvoltage
Here is a no welding version. Bend the tabs in on the wall mount with a crescent wrench, give the cactus looking skull mount a 90 degree twist and its ready to go. Gravity keeps the pivot locked i to the tabs well so the skull stays put. We have sold several of these and they work great.
Skull Holder.dxf
donn92
Post by donn92 »
Highvoltage wrote:This is my version. Can make them any animal you want as a mounting plate.
very nice any chance your willing to share the file
steel 35
Post by steel 35 »
[quote="Highvoltage"]Here is a no welding version.
Nice! & Thanks
PPL HDG 4X8
Hyp 65 duramax's
EasyScriber
Highvoltage
Elk head and broad head European mount files. I bought bullet hinges from the local steel supplier. The kind used on gates. The slots in the middle are welding guides for the hinges.
Broadhead.dxf
Elk .dxf
Limitless
Post by Limitless »
Thanks!!!
Mel & Jess
Owner/Operator
Limitless Metal & Wood Custom Design
Torchmate 3 - 5x10 - Plasma/Router/Plate Marker
Hypertherm Powermax 85
Torchmate Cad
mlmtx01
Post by mlmtx01 »
Highvoltage wrote:Elk head and broad head European mount files. I bought bullet hinges from the local steel supplier. The kind used on gates. The slots in the middle are welding guides for the hinges.
I can't get this file right. It keeps saying it needs to remove duplicate vectors in my sheetcam application. I can't find any duplicate vecotors in vcarve.
