Making Eccentric Bushings Howto
I just got through with a "Making an Eccentric Bushing" web page.
In the instructions I use a minilathe and a 4-jaw chuck. I have a little excerpt at the end on using a drill press as well.
You can find the posting here:
Please let me know what you think
http://www.kronosrobotics.com/making-an ... c-bushing/
Re: Making Eccentric Bushings Howto
Thanks for re-posting my video
I think I have made about 600 of those to date.
Since I got it perfected, I have made about 50, in the last 3 or 4 days. Mine is a very simple method, but I like how you tap the hole. This allows for some very interesting ways of using the thing. I think I can adapt that to my method by just using a #6 drill for a 1/4-20 tap.
I use a #3 drill for 1/4" X 28 thread.
I just added my own video to the mix. Its meant to go along with the web page.
https://youtu.be/-E4D9dhMS5Q
@acourtjester
If you want me to link to your web site in the text, send me a link and I will add it. Its time we wee little folks started cross linking each other.
@acourtjester
I don't have a web page, thanks for the offer
acourtjester, are you selling those or do you just use that many?
I'd be interested in a set of them if you are selling. Thanks.
I do make and sell them for both standard 1006-2r roller bearings threaded and the "V" type bearing RM2-2RS through bolt 1/4"
In not selling them right now, but will probably offer them when my book is finished. I will also link to others who are selling them. I like to give options when sourcing parts.
I have been playing around with other sizes as well.
From left to right
V-Bearing RM2ZZ
Skate Bearing 608ZZ
1/2 x 1.125 Bearing R8ZZ
From left to right
V-Bearing RM2ZZ
Skate Bearing 608ZZ
I just added a 3-jaw chuck method to the web page.
I was able to create these three small bushings using that method. These are small bearings with a 6mm opening. I'm using a #6 machine screw as the fastener.
You can find the 3-jaw chuck writeup here:
Its located at the bottom of the page.
I'll check the size on my bearings and get a set from you then. I have eccentrics on my v bearings but not the regular rollers. Seems like a worthwhile investment.acourtjester wrote:I do make and sell them for both standard 1006-2r roller bearings threaded and the "V" type bearing RM2-2RS through bolt 1/4"
msimpson99, thanks for posting up that you aren't selling them yet, I was afraid I was crapping on your thread.
No problem
acourtjester has been a great help for me as I have been doing the research for my book. Hell, I was about ready to order some from him as well, but he convinced me I needed to get a lathe. Which is good as I want to make several size bushings for various projects.
