Another quick one before my phone battery dies. I keep getting a slight wiggle on some cuts. Drive gears etc perfect. Torch shield only just holding it together till i got the new one, new everything else in the torch. Prehaps it is a speed thing?
And also, how does one set cut rules in Sheetcam to slow down on corners so i can get small holes better? Anything 20mm and over are perfect, small ones are UGLY!
Wiggle on cuts, and small holes.
Home built 3400 x 1400mm (11 and a bit X a bit over 4.5 feet)
Hypertherm Powermax 45
CandCNC Bladerunner IV
Some air dryer off the internet
Another water seperator I found unused on a shelf
Refrigerated air dryer
- tnbndr
Re: Wiggle on cuts, and small holes.
Go over to to the Sheetcam topic in the software section of this forum and search or read through the posts. There is lots of talk on rules.nd also, how does one set cut rules in Sheetcam to slow down on corners so i can get small holes better?
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
