draftsight__dimensions always the same size
rikduk
Post by rikduk »
Hi,
i am wondering if anyone has a trick to have the text dimension size to be always 1/4 inch high, no matter the scale
of the drawing. On draftsight.
When i want to print sheet dimensions for bending, and set up my dimensions at 1" high, on a 2inch long part, the dimension will appear huge,
but if i use the same setting on a piece 10 feet long, i wont be able to read it on the paper.
i know, i can all change that manually each time, but i was wondering if there was a faster way.
Richard
tnbndr
Re: draftsight__dimensions always the same size
Post by tnbndr »
Not sure with Draftsight, but use help and look up Associative dimensioning.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
