Sheetcam Won't Recognize SVG.
I've created files in Inkscape and save them in svg format and load them on my flash drive to put them into my plasma cutting computer. I load up sheetcam and try to import drawings and all it will show is my dxf files. I running a Linux based system. Also running the latest Inkscape and sheetcam programs. Any suggestions? Thanks
Re: Sheetcam Won't Recognize SVG.
question do you mean you cannot see any SVG named files?
If that is the case go to the box where you see DXF and click on the arrow and it will open a menu with other file names for you to select.
SVG will be one of them click on that and you should now see all the SVG files only.
That was it! I figured it was operator error. Thank you so much.
