Scribe skipping first line?
RandyL
Post by RandyL »
I see there are other post of similar issue, cannot seem to find answer.
History:
just added a scribe to my plasma table, bkaderunner ethercut system.
running post 11D, (I see others have later versions but I don't know where they are downloadable from)
Problem:
Scribe does a peck on first line, then moves to second line to scribe and it run's the remainder of layer fine.
It also stops when it finishes scribe layer, I have to hit run again for it to do the plasma perimeter cut. ( I see the code is telling it to wait for me to hit start). does this need to stop, or can I somehow turn that off so it goes from scribe to plasma?
I can run scribe, I just have to place a line that I do not want and make it my start point. It pecks first line then moves through remainder layer fine..
Any help is much appreciated,
Randy
Precision Plasma
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
WyoGreen
Re: Scribe skipping first line?
Post by WyoGreen »
Hi randy, I seem to remember there being a few bugs with the scribe in earlier posts. You might want to try one of the latest posts to see it it fixes your problem. You can download the latest CandCNC posts from the CandCNC website. http://candcnc.com/index.php/firmware-updates
About halfway down you will find "Support Files Latest SheetCAM TNG (version 6.0.1 or later) with DCC upgrade"
Hope this helps, Steve
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
RandyL
Post by RandyL »
Steve,
with your help I located the latest post 11M1, it was in that download you pointed me to.
I will let you know in a few min if that does the trick..
Regardless, thank you for your help.
Randy
Precision Plasma
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
RandyL
Post by RandyL »
Updated to 11M1
first line cuts now.
New problem, when loading file to mach, it does not completely load code. it stops loading when it hits the end of first layer. so it quits the line before plasma. I forced it through but that is not right...
it also skipped a couple lines in the scribe..
so one problem solved, a new problem surfaced.
Precision Plasma
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
If Mach stops on a line when loading it means that line is bad (has a problem)
RandyL
Post by RandyL »
Ok, I will see if I can resolve the bad line issue. I will update with findings.
Thanks Acourt..
Randy
Precision Plasma
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
RandyL
Post by RandyL »
Mach is loading complete file now.. not sure why..
still skipping random lines. It seems to run cursive letters fine, skips on apostrophe square, one side (between letters) (scribes 3 of the four sides of square sides)
when I load and run the 2"sq box with x open lines it makes one dot on line, moves to next line and makes one dot and stops.
It looks to me like code is not correct in mach? looking for ideas on how to resolve. why would it cut out non straight lines and not simple straight lines?? :?:
Precision Plasma
5 * 10
CandCNC ETHERCUT
Bladerunner Stepper
Hypotherm 65
