Spa Sign
Spa Sign
here is a custom sign for a Spa to list specials of the day that will be located near the pool. The dry erase board is attached with industrial strength velcro. There are two pieces of channel welded to the back of the sign with key holes machined for hanging and quick removal for bad weather. The material is aluminum. The towel is press fitted over the lady on the table using fold over tabs. I also chisled a line into the towel for a detail and used a rounding hammer to break the edges for nice look. I did the design work but the customer owns the rights to the file so I will not be able to post the file.
There is plenty of room at the top - and the top is where you want to be. Whenever you do a project - do the hardest part first and the rest will be easy.
- AnotherDano
Re: Spa Sign
That's a fine job you did for them.
Don't fret about not being able to post a file - it's the idea that needs to get across - for those of us who are creatively challenged.
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
Re: Spa Sign
Very nice job Anvilhead. May I ask what font you used for your sign? I think that is a really neat one and would look good for my shop sign.
Any help would be appreciated.
Respectfully,
James
Respectfully,
James
