Importing Mulitple and Moving Drawings
so i worked up a drawing of the alaska state map. took me a bit. looks good when its cut out. earlier i had imported a moose on a different file name also took a bit of work. i want to put the moose on the ak map. is there any way to put the two files together without having to redraw one of them? the only program i have is the one that pcam came with. no corel draw or anything that picks up dxf files.
Re: moving drawings
Ryno Fab,
In Pcam select your Alaska file, once it's on screen select import,select your moose file,your moose should now be on the same screen as Alaska.Hope this helps,Tim
- AnotherDano
Re: moving drawings
Correct, but add a cautionary step;AIRFLOWKID wrote:Ryno Fab,
When the Map file is on-sreen, save it as Map&Moose. That will become the current file. Then import the moose. It will appear in green, so be sure to move it away from any overlapping situation before allowing it to become 'unselected'.
Save that file just 'in case...' and begin your changes.
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
Re: moving drawings
maybe im doing something wrong, but when i try to import something just the bitmaps come up no dxf files. im trying to take an image that i have worked on in the plasmacam cad program and open it on a different page.... ie. i draw a box. save it as ' box'. open a new file and draw a circle save it as ' circle'. now is there a way to open the box file and bring in the circle from the circle file?
- Loyd
Re: moving drawings
Open up the "box" file in P-Cam. Go to file, import and choose .pcm file then choose "circle" the circle will then be on the same page as the "box" file.
Loyd
Loyd
Re: moving drawings
haha man i still cant get it to work. thanks for being so patient.
- Loyd
Re: moving drawings
When you try to import the second file what happens? There should be a window open and you go to the drop down file and choose .pcm. Then choose the file you want and it should go into the first file.
Loyd
Loyd
Re: moving drawings
see when i hit import a window pops open. but no pcm files show up. just my original bitmaps that i have saved. i know the pcm files are in that folder but they dont show up when the import window pops open.
Re: moving drawings
When you click on import and the window opens showing your files, go down toward the bottom of that window and where it says "Files of Type:" click on the drop down arrow and select "G-Code;All files[*.*]". It should now show you all of the files in that folder regardless of the type. If you still have problems, send me your phone number & I will call you and try to walk you through it.
Danny
Danny
Re: moving drawings
oh boy do i feel like a dumb-a. ha ha thanks for the help guys.
- AnotherDano
Re: moving drawings
Why do you feel dumb?ryno fab wrote:oh boy do i feel like a dumb-a. ha ha thanks for the help guys.
D'ya think we all came into the world knowing that stuff?
Here's to the Spider and the good inhabitants therein!!!
Dano Roberts
