Hi all,
I'm looking for someone to cut me some brackets with their CNC Plasma out of 1/8" mild steel. There would need to be 4 copies of the attached .dxf
Quality doesn't have to be perfect!
I am located in Michigan, so that would be nice if local.
Can someone cut me some brackets? $?? Michigan
- _Ogre
Re: Can someone cut me some brackets? $?? Michigan
where in mi?
michigan is a big state
we're located in plymouth
an ogre smiley
how cool!
an ogre smiley
I'm just south of Canton! I'd be willing to drop off the material and pick it up as well if that works better for you.
Have you found anybody to cut these for you? I can cut them and ship to you.
Danny Walker
Walker Mfg.
Danny Walker
Walker Mfg.
- _Ogre
file wouldn't open with autocad 2000
it needs work to nest the shapes or will use a lot of material
yes, i'm stuck in the dark ages
an ogre smiley
how cool!
an ogre smiley
- SeanP
It opened in sheetcam perfect, don't forget you can use the 'Break up manually nested drawing' option to move parts around, its a great feature._Ogre wrote:file wouldn't open with autocad 2000
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
- Capstone
Great Tip Sean. Thanks
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
- _Ogre
agreed, good tipSeanP wrote:It opened in sheetcam perfect, don't forget you can use the 'Break up manually nested drawing' option to move parts around, its a great feature.
i typically do everything in autocad and use sheetcam for tools and g-code
an ogre smiley
how cool!
an ogre smiley
I'm in Troy mi, if you still need this done. Shoot me a pm if so, I'll work up a price for you.
Have great day.
Have great day.
