while this enclosure may not work for everyone, it could be adapted to any compressor
my own craftsman 5hp shop compressor is under the stairs in my barn to keep the noise level down
when we moved to the new shop 10 yrs ago we used a ingersoll rand t30 compressor, rated at 24 cfm, 7.5 hp, 240/480v, 3 phase
we used it hard, had to rebuild the head every couple years, new motor 5 yrs ago
it was great for a couple of employees using air tools, but not so good for 5 employees, air tools, paint booth and a plasma table
it finally died from overheating
we used this gardner denver compressor in our old shop 15 yrs ago, where it had it's own room away from anyone
i had purchased it from an ex-employer when they upgraded to a screw compressor
it is a beast. rated at 36 cfm, 10 hp, 240/480v, 3 phase
it has cast iron cup valves that clatter and get louder as the pressure builds
it's so noisy that it drowned out any conversation 200 ft away
we pulled it out of storage to replace the t30 compressor when it died and have it setup in the fab shop
a couple sheets of plywood and a roll of egg-crate style sound dampener foam later; we can now converse standing next to it
we started the enclosure off the original shipping crate using a few 2x2 studs and plywood screwed together
it has an internal baffle to keep the noise down and a 240v furnace fan that comes on with the on switch
the fan runs all day and helps to keep the head, motor and tank cool, while the compressor cycles
the whole interior is covered in egg-crate sound dampening foam
access doors allow us to check the oil level, drain condensate and service the air filter
the main air valve is located outside the enclosure on the far end
