STUD WELDER HELP
STUD WELDER HELP
Seem to be getting alot more multiple layer stuff.... been using 3m tape with success but the standoff look is much better. Seems that a CD stud welder is the way to go. Any suggestions on make & model???? If it will do 1/4" studs,, more that enough.
Salty Dog
Salty Dog
- SlagBandit
Re: STUD WELDER HELP
Not sure about everyone else but I use 1/4" bolts welded to the back of my parts with a alignment hole for the back section. I looked into "actual" sign standoffs and they wanted $2 a piece! Well to hell with that! $1.89 lb for a bag of 1/4" bolts. Just what I do. To each his own!
Torchmate 4x4 Growth Series
Hypertherm Powermax 45
Torchmate 1 5x10
Hypertherm Powermax 85
Miller 225 MIG
Miller 210 Syncrowave TIG
Torchmate 1 5x10
Miller 225 MIG
- little blue choo
Hey SlagBandit, any photos to how you do yours?SlagBandit wrote:Not sure about everyone else but I use 1/4" bolts welded to the back of my parts with a alignment hole for the back section. I looked into "actual" sign standoffs and they wanted $2 a piece! Well to hell with that! $1.89 lb for a bag of 1/4" bolts. Just what I do. To each his own!
Rick
Arclight 9600 4x8 table
You're right in wanting a CD or capacitor discharge for our lighter type work, weld mark shouldn't show through on anything from about 1.0mm material. A good system is good for mild steel, aluminium, copper and stainless. Drawn arc is really for heavier material.
Not sure if they are available over there but probably one of the most widely used ones I've come across here is the KCD Stud Welder. There are also a few Chinese ones around but the ones I've seen don't come close in performance.
A bit of info on CD http://www.kcdstudwelding.com.au/Capacitor_Discharge
Murray
Murray
I tried the stud welder and it did not work for me very well. So, I also use 1/4 x 1 1/2 bolts. I put both layers together, drill a 1/4" hole through both layers. Put the bolt through the bottom layer, enlarge the hole in the top layer to 5/16. Then, weld the top of the bolt to the top layer through the hole (rosette weld). Attached at a couple of examples, I will get pictures of the actual bolts and welds later this week.
Hope this helps.
Hope this helps.
- SlagBandit
Here are some pictures of a simple sign I did for my son. The pictures are pretty self explanatory. You can do the same thing with multiple layered signs you just have think things through a little more. I just cut the holes for the bolts when I cut the piece. I just make sure everything lines up in CAD first. The benefit of doing it this way is you can take them apart and repaint if you don't like the colors or from age.little blue choo wrote:Hey SlagBandit, any photos to how you do yours?SlagBandit wrote:Not sure about everyone else but I use 1/4" bolts welded to the back of my parts with a alignment hole for the back section. I looked into "actual" sign standoffs and they wanted $2 a piece! Well to hell with that! $1.89 lb for a bag of 1/4" bolts. Just what I do. To each his own!
Torchmate 1 5x10
Miller 225 MIG
Torchmate 1 5x10
Miller 225 MIG
- SlagBandit
You still looking at stud Welders?saltydog wrote:Seem to be getting alot more multiple layer stuff.... been using 3m tape with success but the standoff look is much better. Seems that a CD stud welder is the way to go. Any suggestions on make & model???? If it will do 1/4" studs,, more that enough.
Salty Dog
Torchmate 1 5x10
Miller 225 MIG
Torchmate 1 5x10
Miller 225 MIG
This seems like way more work than needed to get this look.SlagBandit wrote:Here are some pictures of a simple sign I did for my son. The pictures are pretty self explanatory. You can do the same thing with multiple layered signs you just have think things through a little more. I just cut the holes for the bolts when I cut the piece. I just make sure everything lines up in CAD first. The benefit of doing it this way is you can take them apart and repaint if you don't like the colors or from age.little blue choo wrote:Hey SlagBandit, any photos to how you do yours?SlagBandit wrote:Not sure about everyone else but I use 1/4" bolts welded to the back of my parts with a alignment hole for the back section. I looked into "actual" sign standoffs and they wanted $2 a piece! Well to hell with that! $1.89 lb for a bag of 1/4" bolts. Just what I do. To each his own!
So the nuts on the back are to give it that floating off the wall look? How did you hang it on the wall?
So you line both pieces up, drill a hole through one piece, probably mark it with a marker then weld the bolt to it. Throw some nuts on the back then cut them all down. Any time I've tried anything close to this you really have to grind the crap out of the front piece to avoid seeing the haz and a little pimple of the weld from the other side.
All my layered stuff is small. The largest is maybe 12"x12" but my solution is super simple. No drilling holes or cutting or any of that fancy stuff.
Buy a lot of those small tiny rare earth magnets. I have some that are 1/16" thick. I could get thicker but I haven't had the need to yet. And simply use a dot of glue on the magnet to get it to stick to one piece. Then the magnets hold themself to the other piece. Pull apart and repaint if needed.
Some pieces I use 12 magnets and it's super strong and works well.
Torchmate 2x2 - Flashcut
Powermax 45 - Machine torch
Taig CNC Mill - Flashcut
Razorweld Distributor
- SlagBandit
Using magnets would work on smaller projects but on larger and outdoor stuff it wouldn't. As far as dimples in paint, I just turn the heat down on the MIG and move fast! I rattle can the smaller stuff and powder coat the larger outdoor stuff. It also depends on the steel you are using. If it has a mill scale or if its cold rolled makes a big difference on standoffs showing through. I generally primer all rattle can stuff so that helps cover up blemishes.
Torchmate 1 5x10
Miller 225 MIG
Torchmate 1 5x10
Miller 225 MIG
So you are saying if it's got mill scale it will show through the front easier?SlagBandit wrote:Using magnets would work on smaller projects but on larger and outdoor stuff it wouldn't. As far as dimples in paint, I just turn the heat down on the MIG and move fast! I rattle can the smaller stuff and powder coat the larger outdoor stuff. It also depends on the steel you are using. If it has a mill scale or if its cold rolled makes a big difference on standoffs showing through. I generally primer all rattle can stuff so that helps cover up blemishes.
YES..still looking.... so far the GRIZZLY CD welder is our choice. Just need to save up the $$$$$
- SlagBandit
Yes! Cold rolled tends to clean up with a grinder a bit smoother. Just my experience.gamble wrote:So you are saying if it's got mill scale it will show through the front easier?SlagBandit wrote:Using magnets would work on smaller projects but on larger and outdoor stuff it wouldn't. As far as dimples in paint, I just turn the heat down on the MIG and move fast! I rattle can the smaller stuff and powder coat the larger outdoor stuff. It also depends on the steel you are using. If it has a mill scale or if its cold rolled makes a big difference on standoffs showing through. I generally primer all rattle can stuff so that helps cover up blemishes.
Torchmate 1 5x10
Miller 225 MIG
Torchmate 1 5x10
Miller 225 MIG
