Not sure if this is the right place to ask but am after a picture of the marker used to draw a pattern before cutting it. Have seen it on here before but can't seem to find it again.
Thanks in advance.
Mtw fdu.
Spring loaded Sharpie
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
Proma THC
Laser cross hairs
Re: Spring loaded Sharpie
Thanks for that info Corfabrication...it will be a BIG help.
Much appreciated.
Mtw fdu.
Much appreciated.
Mtw fdu.
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
I went a different route and used a pen insert so I could get a finer line and it will not dry out like a sharpie will when sitting not being used. I turned the plastic to fit the torch holder. The bolt at the top is for pressure adjusting the pen insert. It allows me to use the floating head as the insert will retract and the outer part will trip the switch.
- steel 35
acourtjester wrote:I went a different route and used a pen insert.
Dang took me two weeks to find this one. Thanks again..
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
We tape a tube to the cutting head, drop a sharpie in, and put a small piece of rod on top of the sharpie for weight. Works like a champ for free.
George Litton
