Sheet metal rollers
All topics related to bending, forming, notching, drilling, saw cutting, etc.
RGR
Sheet metal rollers
Post by RGR »
I looked so hopefully this is tn a repost. I wanted you guy's opinions on a ring roller to roll metal plate. I wanted to find one that can do 1/8 but I keep seeing 16ga-20ga rollers. I want to make some round fire pits for me and my family as gifts. And I think a good roller would be a good tool to have on hand. I know a lot of you guys have one so what can you recommend me to buy??? Thanks! Everyone here is always a great help!
tnbndr
Re: Sheet metal rollers
Post by tnbndr »
I would scan craiglist, ebay, etc for an older slip roller from Pexto, Roper Whitney that is rated for 10 gauge.
I have a 36" pexto rated for 16 gauge, which is what should handle full length. It will roll 12 gauge fire rings, 12" wide but it complains. I have converted this roller to motorized so that may be part of the problem and I may fool with gearing when I get time.
I am always searching for a replacement rated for 10 gauge.
Now I like the older American made machines. Some here will also tell you to look at Baleigh, Jet, etc. and they will probably work for your needs.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
RGR
Post by RGR »
When you say "older" is that a 1950's machine or 70's era? I know that now a lot of equipment is import, but I'm not sure when this big import era really started. If I had to guess Id say 1980's? I'll look for the brand names you said and see what I can find. Thnaks for your help, gets me pointed in the right direction
tnbndr
Post by tnbndr »
My "older" machines are from the 50's - 60's era. But I think you are correct the real flood of imports started in the '80's.
K D Metalwerks
Post by K D Metalwerks »
I found an "older" Niagra slip roll that works fine for me. Rated to 11 gauge, I can roll 12" wide stuff all day. Sure, it cost more than an imported model similar, but I have no doubts that I will ever wear it out or break it.
K D Metal Werks
PlasmaCam DHC2
Hypertherm Power Max 45
Hobart Handler 190 Mig
Niagara 3"x 36" Slip Roll 14ga
Driess/ Krumph 4' box & pan brake 16ga
Hossfeld #2 Bender Ridgid 700 threader
Pexto 137-1 16ga. Stomp Shear
MADE IN USA
I just ran across this today and if your interested you can check it out.
This guy made a simple ring roller for rolling plate steel he said 3/16" you can see it here scroll down to post #19.
http://www.pirate4x4.com/forum/shop-too ... st13060138
the 2 bolts are used to pressure adjusting to change the diameter, not something for mass producing very many but for a few fire pits it may do for you..
have fun
Tom
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
