Wondering where you guys would be at price wise on this to cutout.
Customer supply's 1/4 Aluminum sheet 6061
1 hour of taking measurements off old skid plates/cad time
595 cut inches, 27 pierces
I haven't cut much out of aluminum to figure out price yet, Just a few piece's for my own projects. Would it be about the same as steel?
Aluminum cut price?
Aluminum cut price?
- tnbndr
Re: Aluminum cut price?
You are just cutting and not welding together?
I would be somewhere around $200, without doing any cleanup.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
- _Ogre
aluminum cuts the same as steelHellfireOffroad wrote:I haven't cut much out of aluminum to figure out price yet,
an ogre smiley
how cool!
an ogre smiley
Thanks! So I wasn't to far off then, I quoted $185, An still got the " Man your way expensive" Will see if he comes back with the project or not. At least I got paid for the Cad time.tnbndr wrote:You are just cutting and not welding together?
You are correct no welding/clean up, Straight off the table.
wow I am at $40 cut speed is 54ipm what do you guy charge by hour?
Is that including the 1 hour of your labour for taking measurements. I think lots of the guys here might subcontract their work to youmodnoc13 wrote:wow I am at $40 cut speed is 54ipm what do you guy charge by hour?
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
No that was just cuting out the file
for one hour of measuring and cuting I would be at $105 at 65 a hour
I would probably be around $125ish for an hour of cad and 15 min or less cycle time running on low amp consumables. Just guessing off the total cut inches and adding rapids.
Owner at Illusive Design & Fabrications
http://www.illusivefabrications.com
Air Ride Suspension Parts
Metal Fabrication
Dynatorch 4x8 with Hypertherm 1250
Vinyl Decals & Signs
Powder Coating
Metal Fabrication
Powder Coating
I came up with 130.00
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
