Powermax 45 hand torch trigger switch
I need to buy the trigger mico switch for my hypertherm 45 hand held torch any help would be great
Re: question for Jim Colt
Best bet is to contact tech service at Hypertherm....they can help you with troubleshooting (if needed) and can ensure you have the correct part number to order a switch.....the order can be placed through any Hypertherm distributor.
It is rare for the switch to fail.....so be sure you have adequately checked out the wiring as well as the PIP (parts in place) microswitch in the torch body as well.
1-800-643-9878 Hypertherm Technical service
Jim Colt
Jim Colt
brucegolinski wrote:I need to buy the trigger mico switch for my hypertherm 45 hand held torch any help would be great
thanks for the info. the plastic tits on the trigger switch that hold the metal arm wore out
From the operators manual fro a Hypertherm Powermax45:
