General question about any plasma cutter
beefy
Post by beefy »
My Hypertherm PM1250 requires a DRY relay contact for the start signal, and gives a DRY relay contact for the Arc OK. Is this pretty much the same for just about any brand plasma cutter. I'm designing a circuit board that interfaces with plasma cutters and am trying to make it as universal as possible, but at the moment it's based on these dry relay contacts.
Keith.
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
Re: General question about any plasma cutter
Post by jimcolt »
Dry relay contact refers to a mechanical relay as opposed to a solid state type relay. Solid state relays generally have a small amount of bleed current......mechanical "dry" contacts do not.
beefy wrote:My Hypertherm PM1250 requires a DRY relay contact for the start signal, and gives a DRY relay contact for the Arc OK. Is this pretty much the same for just about any brand plasma cutter. I'm designing a circuit board that interfaces with plasma cutters and am trying to make it as universal as possible, but at the moment it's based on these dry relay contacts.
Keith.
beefy
Post by beefy »
Thanks Jim,
I know all about the mechanical vs solid state relays. I used to be an industrial electrician and I also play with electronics.
I was more wanting to know if most plasma cutters use the same system as my 1250, i.e. requiring dry (mechanical) relay contact for START and giving the same for ARC OK.
Keith.
LinuxCNC
Coreldraw 2019
Post by jimcolt »
All of the Hypertherm Powermax units do, I cannot speak for other brands.
beefy
Post by beefy »
Thanks Jim,
Keith.
LinuxCNC
Coreldraw 2019
rikduk
Post by rikduk »
WhEn you say dry contact, its basically like if you just shorted the two pins together, right?
I'm trying to make a feature run on mine, it requires dry contact closure or 24 vdc.
Nothing happening...
beefy
Post by beefy »
Yep, that's pretty much what "dry contact" means. I simple switch is pretty much the same thing. You are not connecting to any other electrical circuit.
In a mechanical relay the contacts "should" be completely isolated from the coil and associated voltage.
Keith.
LinuxCNC
Coreldraw 2019
