Here are a few things that have been working well long enough to share.
To help hold down material on the table I use bar bell weights hanging from some round, there is tab on top to hook the material and a handle about 6? down. They are short enough to stand under the grate and are lifted through the grate to hold things in place. I have four sitting under the table
Magnets from computer hard drives are great for making hold downs for finishing. I routed out a space for 3 magnets in some ? plywood, covered it with a disk of thin metal nailed down then put 4 magnets on the bottom to hold it to the bench and now no more clamping. I also put 2 of the larger magnets on the back of a piece plywood to hold things for airbrushing dyes or paints, works great.
I rigged a counter balance for my grinders from some 1? sq bar, 2 pulleys and some wire cable. The last 4? of cable is picture frame wire size and terminates with a open hook that fits a loop I put on my grinders. Not only does this take some of the weight, its nice to have the grinder just hang there when you need to flip or change parts.
Thanks everyone for your help
Bill
Bow Hunter Antler Design
Download Design
cheap tricks
1 post
• Page 1 of 1
cheap tricks
1 post
• Page 1 of 1
Jump to
- Welcome Center and Meet Our Sponsors
- ↳ Introduce Yourself
- DXF Design and Project Picture Sharing Forums
- ↳ DXF & SVG Categorized Library
- General Forums
- ↳ Plasma Cut Quality Forum
- ↳ Classified Ads
- Plasma Cutter Forums
- ↳ Hypertherm Plasma Cutters
- ↳ Powermax Cut Speed Charts
- ↳ 0-12 Fault Code
- ↳ 0-19 Fault Code
- ↳ 0-20 Fault Code
- ↳ 0-21 Fault Code
- ↳ 0-22 Fault Code
- ↳ 0-30 Fault Code
- ↳ 0-99 fault Code
- ↳ Plasma Consumables
- CNC Plasma Table and Controller Forums
- ↳ CandCNC Forum
- ↳ CandCNC Website
- ↳ FastCut CNC Forum
- ↳ FastCut CNC Website
- ↳ FlashCut CNC Forum
- ↳ FlashCut CNC Website
- ↳ JD Squared Forum
- ↳ JD Squared Website
- ↳ Shop Sabre Forum
- ↳ Shop Sabre Website
- ↳ Star-Lab CNC Forum
- ↳ Star-Lab CNC Website
- ↳ Tracker CNC Forum
- ↳ Tracker CNC Website
- ↳ Langmuir Crossfire Forum
- ↳ Torchmate Forum
- CAD-CAM and Control Software Forums
- ↳ General Discussion
- ↳ BobCAD
- ↳ C&CNC CommandCNC
- ↳ Corel Draw Graphics Suite
- ↳ CorelDRAW Free 15 day trial
- ↳ Inkscape
- ↳ Linux CNC - Plasmac
- ↳ Mach3 & Mach4 CNC
- ↳ Plasmacam - DesignEdge
- ↳ SheetCam
- ↳ Torchmate Software
- Metal Finishing Forums
- ↳ Patina Finishes
- ↳ Paint & Other Top Coats
- ↳ Powder Coat
- ↳ Abrasive & Texturing
- ↳ Dross/Slag Removal
- Accessories and Tool Related Forums
- ↳ Laser Engravers & Cutters
- ↳ Arclight Dynamics
