can you run this g-code?
timberfab
Post by timberfab »
Here are the details short and sweet.
6x12 homebuilt table
the latest candcnc dragon cut electronics w/ DTHC
hypertherm 1650
Table is set up, I'm just trying to set up sheetcam to generate the best, easiest G-code
running the latest development version of sheetcam and the MP3000-DTHCII+dcc+hyt+scriber8 Post Processor.
I had cut rules set up before but it seemed like there was a delay at the beginning of each corner etc. this code has no cut rules just the offset.
Could you run it with no torch to see if it has any delay where the DTHC would turn off and on?
also look at the code and see if it look normal or if there are obvious issues.
I won't be at the shop till much later and just wanted to see if it was me or the code!
N0010 (Filename: circle square test.tap)
N0020 (Post processor: MP3000-DTHCII-DCC-HyT+scriber-8 (newest edit).scpost)
N0030 (Date: 10/7/2013)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 S10 (DTHC is off)
N0080 (Part: circle square test)
N0090 (Operation: Outside Offset, 0, T1: 0.125 steel 45 amps)
N0100 (tool number: 1 Feedrate: 190)
N0110(Preset Volts: 133 Preset AMPS: 45)
N0120 ( Air Pressure Preset: 85)
N0130( Suggested Tip Size: 45 DTHC Delay: 1.5 sec )
N0140 S900
N0150 M22
N0160 S3133
N0170 M22
N0180 S445
N0190 M22
N0200 S885
N0210 M22
N0220 S515
N0230 M22
N0240 M00
N0250(Check the DTHC Settings Hit RUN to continue)
N0260 G00 Z1.0000
N0270 X0.5450 Y0.4845
N0280 Z0.1500
N0290 G28.1 Z0.12 F19.685
N0300 G92 Z0.0
N0310 G00 Z0.0591
N0320 G92 Z0.0
N0330 G00 Z0.1500
N0340 M03
N0350 G04 P0.4
N0360 S20 (DTHC is on)
N0370 M22
N0380 G01 Z0.0600 F3.937
N0390 S10 (DTHC is off)
N0400 G03 X0.6250 Y0.4045 I0.0800 J0.0000 F114.0
N0410 I0.0000 J0.2205
N0420 M05
N0430 G00 Z1.0000
N0440 X2.0450 Y1.2345
N0450 Z0.1500
N0460 Z0.1500
N0470 M03
N0480 G04 P0.4
N0490 S20 (DTHC is on)
N0500 M22
N0510 G01 Z0.0600 F3.937
N0520 S10 (DTHC is off)
N0530 G03 X2.1250 Y1.1545 I0.0800 J0.0000 F114.0
N0540 I0.0000 J0.9704
N0550 M05
N0560 G00 Z1.0000
N0570 X3.5450 Y0.4845
N0580 Z0.1500
N0590 G28.1 Z0.12 F19.685
N0600 G92 Z0.0
N0610 G00 Z0.0591
N0620 G92 Z0.0
N0630 G00 Z0.1500
N0640 M03
N0650 G04 P0.4
N0660 S20 (DTHC is on)
N0670 M22
N0680 G01 Z0.0600 F3.937
N0690 S10 (DTHC is off)
N0700 G03 X3.6250 Y0.4045 I0.0800 J0.0000 F114.0
N0710 I0.0000 J0.2205
N0720 M05
N0730 G00 Z1.0000
N0740 X3.5450 Y3.4845
N0750 Z0.1500
N0760 Z0.1500
N0770 M03
N0780 G04 P0.4
N0790 S20 (DTHC is on)
N0800 M22
N0810 G01 Z0.0600 F3.937
N0820 S10 (DTHC is off)
N0830 G03 X3.6250 Y3.4045 I0.0800 J0.0000 F114.0
N0840 I0.0000 J0.2205
N0850 M05
N0860 G00 Z1.0000
N0870 X0.5450 Y3.4845
N0880 Z0.1500
N0890 Z0.1500
N0900 M03
N0910 G04 P0.4
N0920 S20 (DTHC is on)
N0930 M22
N0940 G01 Z0.0600 F3.937
N0950 S10 (DTHC is off)
N0960 G03 X0.6250 Y3.4045 I0.0800 J0.0000 F114.0
N0970 I0.0000 J0.2205
N0980 M05
N0990 G00 Z1.0000
N1000 X0.0154 Y4.0450
N1010 Z0.1500
N1020 G28.1 Z0.12 F19.685
N1030 G92 Z0.0
N1040 G00 Z0.0591
N1050 G92 Z0.0
N1060 G00 Z0.1500
N1070 M03
N1080 G04 P0.4
N1090 S20 (DTHC is on)
N1100 M22
N1110 G01 Z0.0600 F3.937
N1120 S10 (DTHC is off)
N1130 G03 X0.0954 Y4.1250 I0.0000 J0.0800 F114.0
N1140 G02 X0.1250 Y4.1546 I0.0296 J0.0000
N1150 G01 X3.9370 F190.0
N1160 G02 X4.1546 Y3.9370 I0.0000 J-0.2176 F114.0
N1170 G01 Y0.1250 F190.0
N1180 G02 X4.1250 Y0.0954 I-0.0295 J0.0000 F114.0
N1190 G01 X0.3130 Y0.0955 F190.0
N1200 G02 X0.0955 Y0.3130 I0.0000 J0.2176 F114.0
N1210 G01 X0.0954 Y4.1250 F190.0
N1220 M05
N1230 G00 Z1.0000
N1240 X0.0000 Y0.0000
N1250 S900
N1260 M22
N1270 S10 (DTHC is off)
N1280 M22
N1290 M05 M30
vmax549
Re: can you run this g-code?
Post by vmax549 »
To me the code looks terrible. What is all the monkey business from line 140 to 240??
What does your M22 do ?
Why turn on THC just to turn it back off again ?
Just a thought, (;-) TP
JJsCustomDesigns
Post by JJsCustomDesigns »
Seems to run ok. I ran it thru a CNC Simulator.
http://www.youtube.com/watch?v=JP1IgAd20K4
Im not sure either what is going form 140 to 240 - - M22 is a "Cutting On" Command- Maybe its used for the scribe/ plate marker?
PM me with details
timberfab
Post by timberfab »
Not sure what all that busy-ness is at the top. It just generates it automatically. This is the latest Post and version of sheetcam that Tom from CandCNC recommended
vmax549
Post by vmax549 »
That is a post for the latest auto setting for the newest hypertherm plasma units the M22 is a DELAY (;-).
Seeing you are using the older 1650 unit I am not sure that would be the best post for you. Did your OLD post work ok??
What version Mch3 are you using. That post was designed for the latest V.067 mach3 release.
timberfab
Post by timberfab »
I'll take a look at the exact version, but it was the latest version. my switch to this post came after a discussion about small circle slow down and DTHC off functions. My previous post worked, but did not turn off the DTHC and did not slow down for circles and curves.
It could have been accomplished in sheetcam i guess, but i was looking for a simpler "global" solution than adding cut rules, drawing in multiple layers, building up a tool library with 2 tools for each material. so while i may not be able to utilize all of the features of the new Powermax series cutters and CandCNC automation, the 2 functions I was looking for are present in the POST. slowdown and DTHC off and on (hopefully with no delay)
timberfab
Post by timberfab »
my version of Mach is R3.642.029
vmax549
Post by vmax549 »
IF memory serves me the newest CandCNC POST was designed to run with the latest Version .067 of mach3 AND the latest plugin for CandCNC.
