How do I "strip" mild steel?
Learn and share abrasive & texturing finishing techniques, experiences, and product knowledge here.
Baileigh Inc
Post by Baileigh Inc »
I am looking for a "brushed metal" look and want to "strip" or polish this 2 x 2 sheet of 16g mild steel before I cut it. This way will take me forever. Anyone have any tips or tricks to help me out?
is there an acid that will strip it down?
Better abrasive discs?
Any help would be great.
Shane Henderson
Baileigh Industrial
shenderson@baileighindustrial.com
920-482-3220
Serious metal fabrication equipment
weldor2005
Re: How do I "strip" mild steel?
Post by weldor2005 »
Your choice, Muriatic will take it off in 15 minutes, and vinegar over night. Use gloves and a 1:1 with the Muriatic acid. and the AAA Rule, Always Add Acid.
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
Baileigh Inc
So if I soak the sheet in vinegar it will be stripped in the morning?
Shane Henderson
Baileigh Industrial
920-482-3220
trucutcnc
Post by trucutcnc »
If you start out with cold rolled steel, it won't have mill scale. That's the black stuff you're trying to grind off.
http://www.trucutcnc.com
Ross Carlisle
Jackson, TN
Baileigh Inc
Awesome thank you
Shane Henderson
Baileigh Industrial
920-482-3220
fergy
Post by fergy »
this is what you need
but if you have a look at stripping gear specifically made for panel beaters you may come up with
something that will work for you the one I have in mind is like a wire wheel but has like
rubber tentacles with stuff impregnated in it
have you tried a belt sander?
muzza
Post by muzza »
Doesn't show real well in the picture but this one here is cut from a piece of cold rolled which I dragged 80 grit paper on a hand sanding block vertically down the sheet before I cut it to hide some scratching on the sheet which gave it that brushed look.
weldor2005
With either the acid or vinegar you will have to just use a sanding wheel after it has soaked in it. after acid I just run a wire wheel over it very lightly and then after vinegar it should be about the same.
No one is a believer until they do it.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
fergy
Post by fergy »
this has been brushed not sure if it shows
SomethingMetal
Post by SomethingMetal »
Muratic acid bath and then rinse it really good. It will only take about 15 mins for the mill scale to be eat off and then you can take that grinder and do some pretty work. I had the same problem just wanting a shiny piece of carbon steel. I wore two flap disc out trying to get past all the mill scale :x and then I found that good ol acid!! :mrgreen:
Samson 510
Hypertherm PM85
Baileigh Inc
This forum is great. The vinegar worked perfect.
Thank you guys so much! 8-)
Shane Henderson
Baileigh Industrial
920-482-3220
Baileigh Inc
I just ordered a pallet of cold rolled. 8-)
Shane Henderson
Baileigh Industrial
920-482-3220
weldor2005
If you move enough fast enough quantities of cold rolled works, but since it dont have mill scale it will get surface rust quicker while sitting around.
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
trucutcnc
Post by trucutcnc »
It usually comes in with a light coating of oil. The mill we get it from runs it from coils.
Ross Carlisle
Jackson, TN
boodog710
Post by boodog710 »
I use muriatic acid especially for smaller parts. After removing the parts from the acid I put them in a water/baking soda mix. Baking Soda is a base therefore neutralizes the acid, making it safer to handle. The I wipe off the mill scale and coat with a light coat of paint thinner. This will prevent rust on the parts.
Jack
Baileigh Inc
boodog710 wrote:I use muriatic acid especially for smaller parts. After removing the parts from the acid I put them in a water/baking soda mix. Baking Soda is a base therefore neutralizes the acid, making it safer to handle. The I wipe off the mill scale and coat with a light coat of paint thinner. This will prevent rust on the parts.
Jack
what mixture of baking soda and water 50 /50?
Shane Henderson
Baileigh Industrial
920-482-3220
boodog710
Post by boodog710 »
I have a rectangular container that holds about 10-12 gallons of water. I add one box of baking soda, large box from the grocery store, about a dollar or two. The baking soda will settle to the bottom so stir it up before each use. When you add the parts it will bubble up for about 5 seconds. This is the baking soda and acid reacting together. When the foaming stops, the parts are ready to take out.
Jack
Baileigh Inc
Now I get instant rust after the acid.
Shane Henderson
Baileigh Industrial
920-482-3220
beefy
Post by beefy »
Just tried it myself for the first time. It was great watching the rust just vanish before my eyes.
I rinsed immediately with water then dried with a hot air gun straight away. Painted a couple of hours later and no rust had formed.
About a year ago I used the acid to strip galvanising. You get a lot of fizzing with this and when it has stopped fizzing, either the coating is all gone or the acid has "worn out".
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
modelaratrod
Post by modelaratrod »
Does anyone have a part # or brand of Muriatic acid? All I'm finding is "safer" than Muriatic acid, and the usually translates into doesn't work as well. lol
Thanks.
5x10 Torchmate 2 w/AVHC
Hypertherm PM85 w/ machine & hand torch.
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
I just pick mine up at Home Depot, it is a little diluted than the straight stuff...but it works excellent and is right around the corner. Another place to get it is at most any pool supply store.
Torchmate CAD
tnbndr
Post by tnbndr »
It works just as well.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
steelfx
Post by steelfx »
Both varieties (smelly & not-smelly) work. Read the label when purchasing & look for the
standardized dilution of 31.45% +/- 2%. Muriatic Acid is Hydrochloric Acid, diluted (suspended) in De-Ionized Water.
My favorite Brand Name is TransChem, but any brand will do.
Please don't try to buy Hydrochloric Acid and dilute it yourself. Straight Hydrochloric Acid (which is usually 98% W/V, will kill you dead...in a very short time. (Seconds, actually)
After searching high & low I finally sourced a Small HDPE (Poly) Dip Tank that's affordable & very heavy built. It will hold 4 gallons plus. Great for double-side patina dipping with the Copper F/X? . 2 Gallons of Patina will be about an inch deep & the patina solution can be be drained out and re-used. Or, it can be used as an Acid Tank.
Measurements: 36"Lx18"Wx4"D. Will hold a lot of small cuts for mill-scale & dross removal & if you have two, you can have a dip tank & rinse tank for very little cost.
You can float an empty one on top of your full one for 98% evaporation control & odor.
Just took photos...haven't put the tank on the website, yet. Later today, hopefully.
thanks!
Bill
modelaratrod
Thanks Bill I looked on the website and didn't see any totes to add to my order?
Return to “Abrasive & Texturing”
