muriatic acid soaking bin
abmagrum
Post by abmagrum »
What do you use to soak youre metal in?
How long do you soak for mill scale?
Medium rust ?
Heavy rust ?
Thanks.
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
Mountain Home
Re: muriatic acid soaking bin
Post by Mountain Home »
The best thing I have found to put acid in that is big enough is one of the solid plastic swimming pools that they sell at Wally world. Leaving a piece in the acid over night usually works good.
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
I got a couple of 32 gallon rubbermaid garbage cans with lids. They work great for the smaller parts but anything over 2 ft. - 30 inches needs to have something bigger. One garbage can has the acid, the other has a baking soda mix. I dip in one than into the other and then rinse. I use a small laundry basket with small round holes and a rope to dunk lots of small parts, that way they don't get lost in the bottom of the can and I don't have to go arm-swimming to find them. Larger parts I just set them in and retrieve with long rubber gloves.
Soaking time - usually about 2-3 hours for quick mill scale removal and softening the dross. Leave in overnight and nearly all the dross and mill scale is history. Most times I can take straight to the sand blaster or hit it quickly with a grinder flap disc for the most stubborn dross and then blast.
Torchmate CAD
abmagrum
Post by abmagrum »
Thanks, Gamelord
Arclight 4x4
hypertherm 65
corel x6
mach 3, sheet cam
miller 211 auto set
kbenz
Post by kbenz »
Mountain Home wrote:The best thing I have found to put acid in that is big enough is one of the solid plastic swimming pools that they sell at Wally world. Leaving a piece in the acid over night usually works good.
how do you cover it well enough to keep the acid from dissipating (escaping) ?
CandCNC
Mach3
Draftsight
Hypertherm 65 machine torch
Millermatic 210
Passport plus
Spoolmate 150
Miller Bobcat 225
Mountain Home
I don't,I have it under a shed roof and I just add a little water occasionally.
crazy59860
Post by crazy59860 »
We use a rubbermaid tank like you use for watering horses and cattle. Hubby built a wooden lid and lined it with insulated foam board that fits just inside the tank. It works great for most pieces..
Toni
