Are their any single part, no mixing good clear coats out their that you like for your steel.
That will give almost the same result as Deltron 3000.
Clear coat
Clear coat
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
Corel Draw X5
SheetCam
- Craig
Re: Clear coat
I have been using Permalac (http://www.permalac.com/) for many years now with good results it comes in spray cans and 1 and 5 gallon cans. I have even used it on rusts and patinas with good results. Craig Johnson
Craig Johnson
Re: Clear coat
Thanks, Craig, Will try it.
Corel Draw X5
SheetCam
Corel Draw X5
SheetCam
- Baileigh Inc
Re: Clear coat
$27 a can? Holy cow....how long does a can last? Is there a cheaper solution?Craig wrote:I have been using Permalac (http://www.permalac.com/) for many years now with good results it comes in spray cans and 1 and 5 gallon cans. I have even used it on rusts and patinas with good results. Craig Johnson
Shane Henderson
Baileigh Industrial
shenderson@baileighindustrial.com
920-482-3220
Serious metal fabrication equipment
Baileigh Industrial
920-482-3220
Re: Clear coat
sculpt nouveau has a permalac alternate.... actually it is permalac rebranded.
it is call clear guard. comes in matt and gloss. been using it for 3 years mainly the matt as a way to cut my solvent dyes.
but we do spray all the brewery signs which have a rust patina on them.... good results.
