First attempt
Learn and share patina finishing techniques, experiences, and product knowledge here.
jsd010
First attempt
Post by jsd010 »
This was my first attempt with a piece. Copper F/X with Torch F/X on the stars. Covered it with Lacquer.
Any suggestions to make it better? I had students use an 80 grit wheel to polish it up after taking it out of the muriatic acid.
Josh Dahlem
Ag Teacher
Stanley FFA
jmsrbrt
Re: First attempt
Post by jmsrbrt »
Looks good but 80 grit? Shouldn't have used something finer, like 120? Less pronounced scratches. When I pull stuff out of the muriatic, a few passes with 120 grit, lightly, and it almost looks like stainless.
Corel 12, Turbo Cad
TD Cutmaster 51
San Marcos, Texas
steelfx
Re: First attempt
Post by steelfx »
Josh,
The shinier the steel, the shinier the Copper will be. In finishing or painting, the quality of the end-result is
99% prep & 1% chemistry.
The Copper F/X should be in contact with the steel surface no more than a few seconds.
And, for best results, work in the shade so the chemical/s don't start to dry on the surface of the
steel before you hit it with water to neutralize.
Looks okay for a first time, though...
bw
abmetal
Re: First attempt
Post by abmetal »
I always use an 80 grit flap wheel to clean and swirl the steel.
Allen
Return to “Patina Finishes”
