Storage of mild steel / humidity / rust questions
- Baileigh Inc
Anyone have any tips on storing mild steel in your garage, keeping it from rusting? I live in Wisconsin and the humidity is a killer.
Shane Henderson
Baileigh Industrial
shenderson@baileighindustrial.com
920-482-3220
Serious metal fabrication equipment
Baileigh Industrial
920-482-3220
Re: Storage of mild steel / humidity / rust questions
Here in western Washington we have heavy humidity in the winter months. I store my sheet materials vertically and mist them w/ WD/40 before putting them in the rack. Helps a lot.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
- Baileigh Inc
plain ol Bill wrote:Here in western Washington we have heavy humidity in the winter months. I store my sheet materials vertically and mist them w/ WD/40 before putting them in the rack. Helps a lot.
Why vertical? What do you use to clean it off so paint will stick?
Shane Henderson
Baileigh Industrial
920-482-3220
Baileigh Industrial
920-482-3220
g store mine vertical too saves space.. i also spray with wd40 seems to be working so far. asfor getting the oil off i either use brake cleaner orpaint thinner or it goes in the acid.
is it a pain yea.is it messy yea can be. but it works and its not too expensive. ispray mine from gallon can in one of those sureshot rechargeable pressue sprayers. (brake cleaner gets same treatment but from a 5 gal can)
It's not recomended to clean with brake cleaner if it requires any welding or heating as it can quite easily kill you or permanently ruin your respiratory system. Have a read through the attached linkgary42095 wrote: i also spray with wd40 seems to be working so far. asfor getting the oil off i either use brake cleaner orpaint thinner or it goes in the acid.
Murray
http://www.brewracingframes.com/id75.htm
muzza wrote:It's not recomended to clean with brake cleaner if it requires any welding or heating as it can quite easily kill you or permanently ruin your respiratory system. Have a read through the attached linkgary42095 wrote: i also spray with wd40 seems to be working so far. asfor getting the oil off i either use brake cleaner orpaint thinner or it goes in the acid.
Murray
I had never seen or paid attention to that warning. Thanks for posting.
Bb
