Ideas on how to bend switch plates
All topics related to bending, forming, notching, drilling, saw cutting, etc.
M & N Steel CNC
Post by M & N Steel CNC »
Anyone have any ideas on how to bend the edges of light switch plates?
PlasmaRoute CNC 4 x 4
Corel Draw X5
SheetCam
Baileigh 12 gauge 40 inch box brake
ironhorse
Re: Ideas on how to bend switch plates
Post by ironhorse »
Are you making a switch plate cover to fit over the original swith plate? This is a very open question, can you be more specific?
Greg
M & N Steel CNC
Switch plate cover to replace existing cover.
Corel Draw X5
SheetCam
Terry
Post by Terry »
I just bend the 4 edges on the break and fix up the corners on a mandrel with a mallet works quit well
Terry
tnbndr
Post by tnbndr »
I would cut them out of 1/8" material and not bend anything.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
M & N Steel CNC
Thanks, Terry and Dennis, will try both methods.
Nancy
Corel Draw X5
SheetCam
Metal Man
Post by Metal Man »
I put them behind the plate, fits flush against the wall
M & N Steel CNC
Metal Man wrote:I put them behind the plate, fits flush against the wall
Do you leave the metal solid under the plate and drill holes for the screws.
or just tighten plate to hold in place?
Corel Draw X5
SheetCam
Metal Man
Post by Metal Man »
Cut rectangle in the plate large enough and just use existing screw and threaded holes in box (no holes in your art
Darrell
M & N Steel CNC
Metal Man wrote:Cut rectangle in the plate large enough and just use existing screw and threaded holes in box (no holes in your art
Darrell
OK, Thanks!!
Corel Draw X5
SheetCam
Return to “Metal Bending, Rolling, Notching, Drilling, Saw Cutting”
