I would probably buy this one if you want to do 11 x 17 size scans.Fastyankee wrote: Tue Oct 22, 2024 3:41 pm It might be easier for me to buy a flat bed scanner what’s your thoughts on that ?
https://www.amazon.com/Plustek-Flatbed- ... 017&sr=8-2 Then you won't have to worry about taking a picture with your phone and not having it aligned properly. I would lay your part on a piece of white paper, trace around it with a Sharpie or thin line Sharpie, and scan it in. For larger parts, you could break the paper trace into sections - scan them in, and then put them back together with the software (Design Edge or Inkscape).
It is also possible to place a part directly onto the scanner for a scan, but I would personally prefer not to risk scratching the surface of the scanner.
