Two path rules I can recommend:xnaron wrote: ↑Fri Jul 31, 2020 5:43 pm @robertspark I just re-read your post viewtopic.php?f=4&t=30670&start=100#p187017 I can use the anti dive % with a code snippet in sheetcam that can drop the feedrate. A lot to learn here... Do you have a default set of code snippets/path rules and post processor that use on all jobs or do you find you need to tweak depending on the paths for the specific job and materials?
Code: Select all
On circles smaller than 25mm set feedrate to 75% and output code AVCOFF
AVCOFF and AVCON are gcodes.On corners tighter than 10 degrees set feedrate to 100% and output code AVCOFF 5mm before corner and Output Code AVCON 1mm After corner.
with either M206 & M205 in them or M212 or M211 depending upon your setup.
Looking at your pieces I would recommend you just check your pierce delay (make sure THC is enabled / on so that uccnc waits for ARCOK before the delay starts).
hence I recommend that M205 is always enabled and just inhibit downward motion with M212 and M211
