Willys Jeep Corel Draw to DXF
jimmyrig
Post by jimmyrig »
Well this is my first file contribution...Maybe :)
I hope I did this correct:
Here are my steps so that it may help others, also this way maybe you can catch my mistakes:
Step 1: Locate image ( I just did a basic search on Google images.
Step 2: Copy image save as jpeg to desk top
Step 3: Open Corel Draw, import image
Step 4: Click edit bitmap, this should open image up in photopaint
Step 5: Size image, selct image with pick tool and convert image to black and white .... also select line drawing
Step 6: from here I used a combination of three tools, ZOOM, Eraser, Paintbrush
here comes the fun, you need to erase all floating images. eliminate random black dots that do not connect to anything else, Everything needs to be connected to something else.
Next with the black paintbrush connect all sections of black, Think of it as an island that needs a road to connect it. If its black and not connected it will just fall out .
Step7: save worked image
Step8: import it back into corel draw.
Step9: Select image trace... You can play with different types to get the look you want, play with sharpness, corners, ect.
Step 10: I then clicked on the image and made sure all nodes were rounded, I also clicked the weld tool, not sure if that did anything buy sounded good
And that is basically it.... I did catch a few hangers that I missed that will fall out when I cut.....
Now if anybody wants to show me how to punch out the words ( Willys ) on the windshield section I would be grateful...
jimmyrig
Re: Willys Jeep Corel Draw to DXF
Post by jimmyrig »
Oops...This first one was well I have no idea ....
jeepwillys.dxf
Eagle Mtn Metal Works
Hi jimmyrig nice file: Do you have a army tank? :?: I want to do a wall plack like I did on the locomotive for my grandson. He is in to army stuff, so I want to do army tank with his name on the side of the tank. I found one on the website but I can't get to convert to a plc file. Thank's Rod. AZ
Rod S in AZ
Thank you for your first contribution, Jimmyrig, nice file. For your fist time you did great, I do not use Corel, but that was a great idea to post the steps on how to post a DXF from that software. :idea:
Here you go Jimmyrig, Willy added. If you want a different font just let me know.
jimmyrig
Post by jimmyrig »
i dont but let me see what I can wip up... I love getting practice.....Are you looking for any tank or ? New or older style?
Eagle Mtn D&D wrote:Hi jimmyrig nice file: Do you have a army tank? :?: I want to do a wall plack like I did on the locomotive for my grandson. He is in to army stuff, so I want to do army tank with his name on the side of the tank. I found one on the website but I can't get to convert to a plc file. Thank's Rod. AZ
jimmyrig
Post by jimmyrig »
Thanks Joe will check it out in a bit.
plasmajoe wrote:Here you go Jimmyrig, Willy added. If you want a different font just let me know.
jimmyrig
Post by jimmyrig »
Perfect you even followed the angle of the windshield. I couldn't figure that part out..... Thats in the next chapter of my tutorial book,,,,
jimmyrig
Post by jimmyrig »
Here is my try at a tank
tankdxf-1.dxf
Post by BrianMick »
thanks
Nice tank, I can picture that in some boys room.
