SheetCam Path rules
SheetCam Path rules
When in SheetCam I found when you are using path rules always have the selection in set to “none” under {Always apply rule set} when you are in either (Options/Job options/Path rules) or (Tools/Path rules) menus. One changes both locations what you have there will over ride what you select in “Operations” Jet cutting under Path rules. I was having a problem while cutting which was the DTHC was being told to turn off in places it should not have been off. Then I started making G-codes and seeing what affected the off locations even after having the rule path turned off in the “Operations” menus. This is when I found the having Path rules selected with “always apply rules sets” over rides what I set in the Operations selections.
- SeanP
Re: SheetCam Path rules
Will watch out for that one, it's confusing enough with just the operation rules
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
