Hypertherm pm65 hand/machine torch
trtilton61
Post by trtilton61 »
I am running the Hypertherm Powermax 65 w/machine torch on my table. Can I change from a machine torch to a hand torch( for hand operations) without changing the voltage divider card.
Precision Plasma HDSE-4x8
CandCNC Bladerunner dragon cut
Hypertherm 65
Mach3
sheetcam
I Lean
Re: Hypertherm pm65 hand/machine torch
Post by I Lean »
Yes. Just unplug the machine torch from the front, plug in the hand torch, and proceed to cut. :mrgreen:
chasxjs
Post by chasxjs »
On my PM45, when I plug in the hand torch it by-passes the CNC connector wiring.
I believe the PM65 is the same. If so you should have no problem.
Charles
____________________
DIY 5x5 Folding Plasma Table
Hypertherm PM45
Lagun 4 axis CNC Mill
Shopsmith Lathe
Multiple saws, welders, etc.
As stated in previous replies, simply unplug the machine torch, plug in the hand torch.
Jim Colt Hypertherm
trtilton61 wrote:I am running the Hypertherm Powermax 65 w/machine torch on my table. Can I change from a machine torch to a hand torch( for hand operations) without changing the voltage divider card.
