puor on epoxy clear
blackandtan
puor on epoxy clear
Post by blackandtan »
Have any of you tried using clear pour on epoxy on your art?
weldor2005
Re: puor on epoxy clear
Post by weldor2005 »
Yes, Looks great when it works. I don't consider myself and expert in coating, but it seems that the stuff I used was temperamental to curing completely. Simple enough instructions, 1 part of both Part A and B, mix by hand for 2 minutes (don't use a drill) and then pour. used heat to draw any air bubbles out. about 90% of it was great, but just a small patch that didn't mix well and didn't harden ruins entire piece. I used it on a table that I routed 1/16" down into wood and then put in a tree of life, and poured on top, didn't cure. Then a bar top that I put a 1/8" lip on and the letters SALOON spaced across it and poured on that. all but a few square inches cured. Probably my fault, but that is my 2 cents.
David Finch CWI
Plenty of welders
Plasmacam 4x4 with DHC2
PowerMax 45
Lots of other toys
blackandtan
Do you know how it looked after along period of time? I have read about some of it yellowing over time. Also do you remember what brand you used. The stuff I've seen looks great when first done but I dont know how it would look over time.
weldor2005 wrote:I used it on a table that I routed 1/16" down into wood and then put in a tree of life, and poured on top, didn't cure. Then a bar top that I put a 1/8" lip on and the letters SALOON spaced across it and poured on that. all but a few square inches cured.
That would suck.
weldor2005
This is what I tried. I don't count out user error to this day, but haven't had good luck with trying to get a 1/16" layer, possibly trying to thick in one coating?
http://www.menards.com/main/interior-wo ... c-7964.htm
David Finch CWI
Plenty of welders
PowerMax 45
Lots of other toys
blackandtan
Thanks for the reply. I am just looking at differant options, you never know what you will come up with.
