Made this simple easel out of scrap lumber I had. Fold it up and lean against the wall when done. Make the bottom edge about 42" high so it's at eye level. Works great.
Dave Hanks
Easel
Easel
- CNCCAJUN
Re: Easel
Neat idea . . . will be making one tomorrow . . . .
I think I might want to add some small holes drilled at a slight downward angle that will allow a #6 or #8 finish nails to be placed where needed to suspend the work so I don't get the collection at the bottom.
Looks great . . . I know that is a gun and not rattle can . . .
Thanks.
Thanks.
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Re: Easel
Ok I'm going to ask
It looks like you welded nuts on the back of the front part then used real short button heads to attached the back.
If that what you did how do you locate the holes in the back part????
This seems to give it more depth looks great thanks for sharing
Re: Easel
I use 10-32 stainless steel nuts and button head screws .187" long. Design the parts in (2) layers. The nuts measure about .400" across the points. Draw a .400" dia. circle with a .200" circle centered inside it and use it to locate the nuts where you have clearance to weld the nuts then delete the .400" diameter circles. Cut .200" diameter holes in the back pieces then drill them out to .218" diameter. Make the back pieces a little bigger then the front - about .100" or so all around. Mark the backside of the front with small lines about .100" outside the cuts all around where the back pieces will go. Lay the back pieces on the front piece and mark the holes with a Sharpie ultra fine point marker. Locate the nuts so you can place tig tack welds (very small welds) on (2) opposite corners. I use needle nose vise grips to hold them while welding. After tacking the nuts on I run a (4) flute flat bottom tap thru them because welding will cause the threads to shrink a bit. Works great. And yes, Steve, the paint is rattle cans.acourtjester wrote:Ok I'm going to ask
If that what you did how do you locate the holes in the back part????![]()
Dave Hanks
- CNCCAJUN
Re: Easel
Dave the paint looks great as does all your work.
If I may ask, is most of your work custom?
I see how much work you put into a project and I can not imagine all that work and hoping for the right customer.
And also, thanks for all your contributions . . . and the high bar to aim for . . .
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
Re: Easel
Thanks for the description of the nut mounting file that away for future use.
Re: Easel
I do very little custom work because I end up losing $. Don't figure in the time involved in designing, each design is a project that I can call up with a click when done.CNCCAJUN wrote:Dave the paint looks great as does all your work.
And also, thanks for all your contributions . . . and the high bar to aim for . . .![]()
Dave
