power max 105 swirl rings
So for the powermax 105 is there actually a difference in the 65-85 amp swirl ring and the 105 amp swirl ring? will this change quality ?
Re: power max 105 swirl rings
According to my Powermax105 operators manual the 220994 swirl ring is used with all of the different sets of consumables including Finecut, 45 amp, 65 amp, 85 amp and 105 amp.
There is a different swirl ring available for hand cutting with the Finecut consumables....but it is not recommended for machine cutting.
Jim Colt Hypertherm
Jim Colt Hypertherm
TWSalaska wrote:So for the powermax 105 is there actually a difference in the 65-85 amp swirl ring and the 105 amp swirl ring? will this change quality ?
yea that's what I was thinking and thank you for the reply. I was just wondering because I have two different swirl rings. one says 65/85 amp (220857) and then 105 amp (220994) so I would assume if I use the 105 amp for everything since I don't use hand torch just mechanized, I should be ok ? thank you again for the speedy response.
